Question about Intel Computers & Internet
D945gzIs (intel mother board d945gzis) Q14vr was bunout replaed, after poweron masage display cmos batry low pres enter key,now m/b not stay in power on justswitchoff.wy it so plz telme what I can do.
  • 3 Answers
Do you know what wattage your power supply is? have you checked the bios battery is seated properly inside the motherboard? have you checked the CMOS clear pins are in normal mode and not in CMOS clear mode? its probably going to be one of the 3 things i mentioned above(P.S bad power supply's take out the hardware they're attached to everyday all over the world)
Posted on Sep 22, 2008
When I turn on my tablet it just keeps displaying "Restarting", what can I do?
Did you try factory reset?
You can make this from Android Recovery Menu (this will erase all your personal data!!!)
Pres and hold VolUp and PowerOn keys until you see android logo.(for a samsung tab)
Use VolUp and VolDn keys to navigate in the menu and PowerOn for OK.
Choose wipe data / factory reset, yes erase all data and finally - reset.
Factory Data reset / Hard reset
Regards.
May 28, 2015 | Tablets & eReaders
My system does not read any usb port frivers
Enter the BIOS/CMOS by hitting the appropriate key, during the Power On Self Test. Delete or F12.
Once in the BIOS/CMOS find the option to enable USB support for both 1.1 and 2.0 USB versions. Also enable the option for USB keyboard/Mouse support!
This should sort the problem out!
Give me a shout if you need further assistance, I am here to help!
Thanking you
damnor01
Dec 13, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
Intel G31pr mother board bios not working, am i removed from that board DDR2 Ram does not any beep sound.display not working
Clear your CMOS or reset the BIOS. If it still does not work, unplug the power cable then hold down the power button for 1 minute then power it back on.
Jun 10, 2010 | Gigabyte Matx Intel G31 775 DDR2-800...
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Prompt to enter setup when started
press del to enter to cmos and set to load setup default and select exit and save changes and if happen again replace your cmos battery.
Nov 24, 2008 | Computers & Internet
Intel d845gvsr
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
108
Jul 08, 2008 | Intel D845GVSR Motherboard
Cannot power on PSU
If you know for certain that the Power Supply is good. (tried another in there) then you have a bad motherboard. No, the CMOS battery will not keep it from coming on.
Dec 31, 2007 | Intel Desktop Board D845WN Motherboard
Computers & Internet Logo
977 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
