Question about Olympus Cameras
FE-150 I HOLD DOWN THE POWER BUTTON THE LCD SCREEN LIGHTS UP WITH NO MENU OR ANYTHING THEN AFTER 30 OR SO SECONDS IT TURNS OFF.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
New batteries, check contacts on battery door, or clean the contacts inside with alcohol and let air dry for one hour before powering camera back on
Posted on Sep 23, 2008
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
Why does my Sony Cybershot DSCW370 Turn on but the LCD screen doesnt stay on????
You might have the Power Save Mode on, if camera wakes up after you depress the shutter button and the screen lights up, then more than likely you have the Power Save Mode on? The settings come in 3 values, screen turns off after 30 seconds, next setting is screen off after 60 seconds. Go the the cameras menu and then navigate to Main Settings, scroll down until you find Power Save Mode and adjust it to standard, hope this helps?
Sep 29, 2014 | Sony Cameras
Lenovo R60i wont turn on, power lights come on, go out when power button pressed
Take out the battery temporarily. Wait 30 seconds. Connect the power cord and try to start without the battery. If it comes on, put in battery while laptop is running .
Aug 01, 2014 | Lenovo THINKPAD R60I LAPTOP LCD SCREEN...
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
Kindle was on a game then screen froze and wont do anything
Press and hold the power button for fifteen seconds or so, ignoring the "Shut down?" prompt, until it turns off. Release the button then press and hold it for a second or two until it starts to reboot.
Jan 22, 2014 | Amazon Kindle Fire HD
Computer turns on, no video on lcd or external video. HP Mini 110
Sorry to hear that. To tell you honestly, this sounds like a video card issue. But, of course I will not jump into a conclusion without doing some diagnostics. Kindly try doing a power drain which most of the time causes issues with the display. Follow the steps below please.
  1. Make sure the computer is off. If the indicator lights are still on, press and hold the power button down for about 5 seconds or so, until indicator lights goes off.
  2. Take the battery out of the computer. Do not forcibly take it out. Most laptops have latches to unlock the battery.
  3. If the ac adapter or the charger is plugged in the computer, unplug it.
  4. Without any power source, press and hold the power button down for about 15-30 seconds. This drains electrical static on the motherboard which, again, most of the time causes issue with the display.
  5. After 15-30 seconds, put the battery back in and plug the charge into the computer for sufficient power supply and turn the computer back on.
If the display comes back up, then good. However, if you still have a black screen on both the built-in and the external monitor then the problem is the video card. If you have no display on the built-in LCD screen but there is display on the external monitor then the problem is with the LCD itself or the inverter cable, a cable that connects the LCD to the motherboard. I hope this fixes the issue though.
Thank you for visiting FixYa! have a good one.
May 10, 2011 | HP Mini 110-1037NR Netbook
Screen is snow white cant see anything. toget to menu.
Hello :
All you have to do is hold the home button and the power button down at the same time for 30 to 40 seconds or until you get a Apple sign on your screen. This will reboot your iPod .
Please rate !
Apr 18, 2010 | Apple iPod nano
How the unlock osd
OSD Lockout in HP Monitors First restart the Computer. Then hold down the menu button for 30 seconds, the main menu appears, then exist the main menu, then remove power cable of the monitor, then hold down the power on button of the Monitor for 30 seconds, then plug the power cable to the monitor. The OSD Lockout problem set rights.
Nov 12, 2009 | HP vs15 15"LCD Flat Panel Monitor
Sansa e260 screen stays black at power up.
Have you tried holding the menu button down for 30 seconds to reset the devise?
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
