Question about Whirlpool Refrigerators
Fridge freezer intermittently not switch on to keep temperature at freezing temperatures. When you switch off at wall and then on again compressor starts and within a couple of hours temps are ok. The compressor then seems to cycle on and off ok with temps ok also. Then several hours later the temps are up arround 0 degrees and compressor is not switch on until, you switch off at mains and back on again. Then the process is repeated.
  • patdorrian Sep 22, 2008
    Hi Huuum,
    Thanks for your speedy response. The Fridge/Freezer, which is my sons, is 5 year old Whirlpool electronic frost free using an airstream system. Sorry dont know the model number at this point ( son lives in Swindon. The unit is in his kitchen. He noticed yesterday when he returned home from nightshift that food within the freezer was no longer frozen and that the compressor/fan was not running.
    He turned off both the fridge and the freezer temperature selectors and then switched off power on the wall socket. After a couple of minutes he turned on power and set temperature switches to their normal settings. The compressor and fan turned on ok. After a couple of hours the temperature in freezer was down arround -17 degees. He had put a thermometer in freezer. The unit seemed to work ok for the rest of the day with the compressor switching on and off as normal. When he left for work, last night, all was ok and freezer temperature was -20 degrees.
    But when he returned home this morning temperatue was -5 and compressor was off.
    I guess its possible that it was in a defrost cycle at that moment or was stuck in a defrost cycle due to a possible failure in the defrost cycle control?????
    Thanks for your help
  • patdorrian Sep 23, 2008
    Hi Huuum,
    Thank you for your reply.
    Yes my son lives in Swindon UK but he is a Scot like I am, although I still live in the land of the kilt and the bagpipes.
    It is a small world as your family are from Swindon.
    I do not think that the freezer was over full. When the problem was first noticed my son found that the food within the freezer was in the process of thawing and the compressor/fan was not running. He then manipulated the thermostats in the fridge and the freezer (still no compressor / fan switch on ),
    unpluged the unit from the mains power. Replugged after a couple of minutes and the compressor/fan started.
    He emptied the freezer and he then monitored the freezer temp. with a thermometer. The freezer ran ok for about 24hrs until he returned from Night shift to find the compressor/fan off and the temp at about -5 degrees. He assumed that the problem had returned.
    Now that I have carried out a bit of self education on frost free freezers, it is possible ( I think) that the freezer may well have been in a defrost cycle when my son discovered the -5 degree situation.
    He is now continuing to run the unit (without food in) and monitor the temperature.
    One explanation for the original food defrost situation could possibly have been exessive dust and dirt
    at the rear of the freezer unit maybe causing a compressor overheat / shut down. Th area has now been thoroughly cleaned. The fridge was pretty empty and the freezer was not over filled when this occurred.
    Thank you for you help.
    best regards
    patdorrian
  • 750 Answers
Hello Patdorrian,
Welcome.
0 Degrees is okay!
How long has the compressor been off when you need to switch it off and on to make it start again?
Perhaps it was on when you were out of the room for a short period?
Is it in a room that you spend hours in to be sure that this is the situation!
Do you have a thermometer in the freezer?
What is the model #.
And how old is the unit?
Waiting your response.
Bless You Huuum
Please remember to leave a rating after you finish.
Posted on Sep 22, 2008
  • Neil Golan
    Neil Golan Sep 22, 2008
    Hello Patdorrian,
    He is in Swindon,UK
    My family is from Swindon!
    Did he have the freezer packet to the hilt and covering the air vents in the rear of the freezer compartment?
    If so, then the fridge and the freezer were unable to share the cold air between them and perhaps the compressor started to over heat and shut off!
    You can not load up a freezer from top to bottom and front to back and block the air passages. Usually the fridge gets warm if this happens but it may cause the unit to shut down.
    Bless You and your son ,Huuum
    Here is a good article that I just read!
    Repair or replace?
    When to pull the plug on your old refrigerator
    It nearly always makes sense to undertake simple do-it-yourself repairs,
    such as replacing a gasket on a refrigerator or a freezer.
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your refrigerator,
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your refrigerator is under warranty or less than four years old (three years for top-freezers),
    paying for a repair makes sense.
    Note that refrigerators under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your refrigerator is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models are quieter and have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new refrigerator.
    Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
    six or more years old or a bottom-freezer or side-by-side eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of a refrigerator you replace is likely to end up in a landfill.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Fridge showing incorrect temperature
The temperature sensor might need to be replaced, however, if the compressor is never shutting off, then the contents of the refrigerator will freeze and the compressor will "freeze up" too.
Buy a refrigerator/freezer thermometer to determine the actual temperature.
Dec 15, 2015 | Refrigerators
My KTM3900WB fridge/freezer is not freezing and cooling in the fridge. The light goes and can hear the motor is running.
You are either low on freon refrigerant, or your compressor is frozen (usually due to low freon) or your compressor is bad. the motor will cycle on and off even though the compressor is not working. the refrigerator away from the wall and look compressor will be a nerf football sizedand usually black cylinder. It could be very hot or cold/frozen. can also unplug the refrigerator leave it for a few hours and plug it back in if it work you are low on freon. You need a repairman
Jan 04, 2015 | Refrigerators
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Fridge turns on off intermittently
I have had a similar problem where the fridge kept turning on and off. This was because the compressor kept overheating due to lack of fresh air. I took the fridge of the wall, disconnected the power and cleaned the area around the compressor using a vacuum cleaner and a brush. Now the fridge would reach te required temperature without constantly switching on and off.
Dec 17, 2013 | Neff K4664 Top Freezer Refrigerator
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Iceream is not freezing
The temperature is not set to high cooling.First check the temperature setting.But if temperature is set right and still the ice cream is not cooling then .Problem relates to weak compressor. ------------- The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that ice cream is not freezing, so that means freezer is not freezing to its required temperature.------- This indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
My Frigidaire side-by-side fridge (model: FRS24XGCW2) never reach freezing temperature in freezer though both side are colder than room temperature. The compressor and fan keep working forever.
1. Check and clean the condenser where system heat is transfered to the air. Located in back behind removable panel, after cleaning make sure you re-install the panel for proper air circulation.
2. Check the back wall of the freezer for ice or frost. If you have frost buildup on the back wall you have a defrost system problem. This would be lated to the timer, heaters, or defrost thermostat.
Jun 02, 2008 | Frigidaire Refrigerators
Refrigerators Logo
321 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
