Orion Tv37rn10d lcd will not go in to freeview mode. I have tryed the reset on the tv and still does the same thing,normal channels 1-5 work fine. when the TV/DVB-T is pressed on the remote,it says ERROR Cannot access digital services,but it was fine 2 days ago Please can somebody help me
5 Suggested Answers
  • 4234 Answers
SOURCE: SONY TRINITRON DIGITAL TV KD-32DX4OU
Unplugging should reset the it, but you may need to unplug it for a couple of hours. Try unplugging overnite. In the meantime, I'l look up the specific model and try to get you more details.
Dan
Posted on Apr 16, 2008
SOURCE: we have a sharp lcd
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Posted on Apr 29, 2008
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
SOURCE: Nikkai A75HQ Digital Freeview Receiver
I'm using an attenuator 3db/5-1000Mhz - I get all channels. Without I got 100% strength,0% quality. hope it helps
Posted on Jan 11, 2009
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I have the same problem - please help as no Cebbies!
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Similar problem
Orion television cannot access digital services
I found the solution on AV Forums. Here's the link:
http://www.avforums.com/forums/lcd-televisions/635155-orion-tv-products-help-advice.html#post6566313
Jun 20, 2009 | Orion STV2763 27" TV
No digital yet tried to retune but greyed out.
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Freeview locked
Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
