Question about SanDisk Sansa e260 MP3 Player
Formatting? ok i need to format my device but the computer won't recognize it and i cant change it to the other USB mode cuz when i turn it on, it just stops at the "Sandisk"screen and then truns off... wut do i do??
  • ljacob8 Sep 22, 2008
    ok scratch that... now it just stays on the Sandisk screen.. and probably wont turn off until the battery runs out...
    it didnt work...
    Problem Solver:
  • 36 Answers
Open the Command Prompt by start menu then choose which drive you want to format Type like this
(your drive name )like K: drive H: drive
format then drive name /q and press enter its gonna be ok
Posted on Sep 22, 2008
Computer won't recognize external usb hard drive
Format drive NTFS sounds like its corrupt, use mini partition wizard...
may also need 3TB Unlocker from manufacturer of Hdd
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
I have sansa clip 2gb. I reset it completely. When I turn it on again i find the same settings again. Ive tried everything every kind of formatting but its setting wont change nor the data on it could be...
Plug it into your computer via USB, then copy the files over. Make sure you are formatting the memory card, and not the camera's internal memory. As a side note, formatting the card will not reset the settigns, and resetting the settings will not format the memory card
Mar 08, 2011 | Cameras
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Computer willnot recognize sansa clip, Begins coonection and then ends imediately after. I have downloaded wmp 11 and i run xp, help?
ok, look turn your device on and select settings, next you want to find usb mode (wording may vary). select this option and change this setting to msc, i have a 2 gig clip and this seemed to work......if this doesnt work try the mpt setting under the same "usb mode" option.....also when putting songs on your device, make sure the files are in wma format(windows media audio) to do this , see the songs properties, ussually done with a right click on the songs shorcut or logo.....if the file is in mp3 format, open the song in windows media player and open the library tab, highlight what you want to put on your device right click and select send to .....then select audio converter, convert the files then send them to your clip.
Mar 30, 2009 | SanDisk Sansa Clip MP3 Player
Deleting songs
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Feb 10, 2009 | GPX ML648B MP3 Player
Cannot reformat my USB 4gb kingston
the reason is ur pen drive has lost its capacity to store datas. u cant use that pen drive anymore and it cannot be formatted also. try for a new pen drive
Jan 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can not sync songs on mp3 player
Jan 07, 2009 | GPX ML648B MP3 Player
Usb drives show write protected when plugging in any device
ok, i found having the flashdrive in a usb hub doesn't help this (http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip ) repair kit to work cuz it can't recognize the flash drive.
so i took ejected it and put it straight into the computer usb and then tried again to format it and hooray. it formatted.
so i managed , thanks
adele
Nov 15, 2008 | iLO (2 GB) MP3 Player
How do i format my sandisk cruzer mini 4gb
To format this device better if you connect it to your computers USB port and let first the computer to recognize it, then when its already recognize by the computer double click Mycomputer icon and you should see there sandisk , just right click on it then click on format.....
Oct 27, 2008 | Computers & Internet
GPX MW6815DT trouble
For those that still use this mp3 player here are some things you need to know.
the gpx mw6815dt can operate as a media player or a usb storage device.
you need to change which state it is in via the System option.
Enter (Sys) from (Mode) go to (Online Device) enter (Mode) select USB Disk or Media Device. When you connect it as a USB Disk you will see all files not shown when connected as a Media Device using windows explorer. Also I suggest you make sure if you format the GPX you stay with the FAT 16 file system.
Note: DRM only works when the gpx is in Media mode.
If you have an SDcard installed you can access it via windows explorer or media player as a usb device only. With media player 11 you can still sync both the internal and sd drive with your library however you won't have drm options since your in usb device mode.
Note: in order to have both usb drives avaiable you need to use the Multi Drive option under (Online Mode) in the (System) menu, other wise you won't see the sdcard.
Feb 15, 2006 | GPX MW6815DT MP3 Player
SanDisk Sansa e260 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
