Question about Mintek DTV-263 26 in. LCD Television
DVD PLAYER WILL NOT ACCEPT DISC
THE DVD PLAYER WILL PULL IN THE DISC & SPIT IT RIGHT BACK OUT. I AM TRYING TO FIND A REPLACEMENT DVD MECHANISM.
THE DVD UNIT/MECHANISM HAS A PAPER STICKER ON IT STAMPED WITH;
TYPE: 260TV*
DATE: 050625 D
NO: 0112 h
TEST: 2
PLEASE ADVISE AS TO WHERE I MIGHT BE ABLE TO GET ONE OF THESE REPLACEMENT DVD UNITS.
THX !!!
DVD player will not acceptdisc
    Problem Solver:
  • 7 Answers
Call 909-974-2859, they have the parts and tech support for this TV.
Posted on Sep 28, 2008
  • tradepro Sep 28, 2008
    call 909-974-2859, they have the parts and tech support for this TV.
Try to reset the dvd decoder only, under the unit should be a reset button.
Posted on Sep 22, 2008
Hi My G6 Radio Works Just Fine, However The CD Player Acts Like It Is Going To Take The Disc
Disc loading mechanism fault. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 28, 2017 | Televison & Video
How can I fix
Sounds like disc loading mechanism fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 20, 2016 | Televison & Video
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
The power button is on but I can't get it to open, any suggestions?
If Your players power is on and refuses to open, it is either the disc tray is jammed or the mechanism is not functioning properly, what You have to do is to service the mechanism, To service the disc tray please follow the steps below:
  1. The instrument You will be needing is a screwdriver and gloves,
  2. Power off the player,
  3. Unplug it from the power outlet,
  4. Then You allow it to rest for about 6 hours, Then You put on Your gloves, and unscrew the screws around the player,
  5. Take off the players cover and check the mechanism on the left side of the player,
  6. Plug in the player then You power in on, press the open button and see if it will attempt to open, once it attempts to open,
  7. Then You apply a little force in pushing the disc tray in the direction it is supposed to open,
  8. Pull it out and in several times till it seems free and opens on its own when You press the open button,
  9. If it still does not open on its own, then it means the mechanism is bad and need to be replaced.
  10. To replace the mechanism, just carefully disconnect it and get a replacement,
  11. Reassemble the replacement into the player,
  12. Then You try to open the player, it will work this time,
  13. Reverse the process to reassemble the player back together.
Hope this helped. Thank You for using FixYa!!!
Jan 17, 2011 | JVC XV-S300 DVD Player
My westinghouse tv/dvd will not accept disc. It shows ''open'' when I push eject and I do not believe there is a disc in there already. When I put a disc in, it sent it right back out and now it will not...
It sounds like the DVD mechanism is out, if you are interested in purchasing one you can do so by emailing your request for pricing and availability to parts@wde.com, they normally run at about $135.00 plus shipping and handling and they are not to hard to install yourself.
Nov 29, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Not accepting cd's
what seems to have is an alignment problem in the mechanism or the optics are also damaged
Aug 22, 2009 | Clarion DXZ665MP CD Player
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Jul 11, 2008 | Jensen VM9510 Car DVD Player
Philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Jan 02, 2008 | Philips DVP642 DVD Player
DVD player shows "no disk" messege even though there is a disk in the player
Either a disk problem, or a player problem. If you get the "no disk" message when using other disks(try originals if you were trying burnt), that aren't scratched, then it's possible that the lens needs cleaning. open the player, locate the lens, and gently brush off any accumulated dust. If you see none, then it will take a more serious repair, possibly to the motor assembly, or the lens mechanism. Good luck
May 03, 2006 | Akai DVDP5851 DVD Player
Mintek DTV-263 26 in. LCD Television Logo
114 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
