Question about Ricoh Aficio 1022 All-In-One Laser Printer
On lcd massage
Sir ,
  My Ricoh Aficio 1022 is Lcd Massege Show in
Add Toner
No Toner : open the cover as Show and Replace Toner Cartridge By Following
instructions Show in Side the Cover
But my toner bottal fell in the half botale
  • Bernard D'Souza May 11, 2010
    is the toner bottle turning ?
  • southbuxtonp May 11, 2010
    Is your toner bottle is still half full? Put cap on end and shake bottle and put back in.
    Check to make sure you are using a good toner - (Part Number)
  • Ricoh Expert
  • 398 Answers
Some times the nipple (cover) of the toner stays in the toner holder this wont allow the new one to be opened
Posted on Jun 23, 2009
Add toner see instructions in front cover to replace toner
Hi
You say you have checked the toner and there is "enough inside", I don't know how you can check this and the error suggests that the cartridge needs replacing. Have you tried a new cartridge ? This is the first step.
Is the cartridge you get the error with a Ricoh cartridge or a compatible. If compatible this could be the cause of your error.
Cheers
Dec 06, 2014 | Ricoh Aficio mp2000 Copier Machine
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How do i replace the toner bottle?
• 1: Open the front cover of the machine.
• 2: Pull the lever and open the green cover.
• 3: Gently pull out the toner cartridge.
• 4: Hold a new cartridge and shake it 10?12 times.
Note: ? Do not touch the "metal contact point" of the cartridge, or it may be damaged.
• 5: Insert the cartridge horizontally, and gently push it in completely.
• 6: Close the green cover.
• 7: Close the front cover of the machine.
Jun 20, 2011 | Ricoh Aficio 1232C Color Copier
My Ricoh CL7000 is saying add toner magenta. But there is plenty of magenta in the cartridge. I've added toner and cleaned out everywhere I can get to. Any suggestions?
It could be a clog in the toner tube, but the most likely (and easiest to fix) problem is the magenta DV unit. Replace the magenta DV unit, turn the machine off and back on, and if it still says add magenta toner open and close the toner cover so that it can load toner, then your problem should be gone.
Nov 08, 2010 | Ricoh Aficio CL7000 Laser Printer
How can I manually add toner to an HP LaserJet 1020 printer?
Get this done through your service dealer. I dont think you can do it manually.
Jan 13, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
Ricoh Aficio 1022 All-In-One Laser Printer Logo
310 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
