TRYING TO CONNECT A VIRGIN BOX TO RECEIVE HD PICTURE TO MY TV, MODEL LE37A456C2D
I trawlled the internet and found a solution, the tv is working fine now, problem resolved.
Many Thanks
Posted on Sep 23, 2008
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
I have a pioneer pdp-502mxe, display screen i am watch my cable tv on it but the picture is fuzzy, would i benifit forn upgrading my virgin box to hd one or would a media reciver solve the problem
upgrading to an HD receiver would very much clear up the picture on flat panel
you are watching a standard definition signal expanded to fit the screen - it is like trying to paint the whole house with one rooms worth of paint
Mar 27, 2011 | Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Just purchased a Samsung LE46C650 LCD tv and it is connected to a pioneer receiver and Virgin V+ HD box. The tv picture lags the surround sound by about half a second. Any way to sync the picture and...
No,half a second that not consider a problems.There are hundred of hardwares and softwares design by dozen of compannies and corporations.Putting these diveces together 100% functionals are not gaureentee.99.99.....% out of 100% is not cosider a problems.
Nov 20, 2010 | Samsung LN46A630 LCD TV
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
No sound when plugging a Virgin Media V+ box through HDMI
have you tried a hd cable this could be the answer if not get back on to virgin as they supplied the box etc they should sort this for you
Sep 03, 2009 | Hyundai ImageQuest HLT-3270 Television
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
Require tv code to use remote
For the V+ remote control (Virgin Media have a picture of it here - http://www.virginmedia.com/images/types7-8n.jpg ) - the code is 0079.
To enter the code, hold down Volume+ and Mute on the V+ remote until it flashes red twice, then enter the code.
Jan 24, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Samsung le37a456c2d
For the V+ remote control (Virgin Media have a picture of it here - http://www.virginmedia.com/images/types7-8n.jpg - the code is 0079.
Aug 02, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
