Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
HOTPOINT KEEPS FLASING F-03
HOTPOINT WASHING MACHINE WF645A 1400 SPIN KEEPS FLASHING F-03 IT DOSENT EVEN GET REALLY STARTED AND IT STARTS CAN U HELP
  • Hotpoint Master
  • 3,463 Answers
The error code F03 indicates that the wash thermistor is open or short circuit.
Check heater element and thermistor,if ok, then you need to call an engineer.
Posted on Jan 04, 2009
  • Linda Farthing
    Linda Farthing Oct 16, 2012
    I have same problem have replaced thermistor and heater element but it is still flashing the code?
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
May 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washing machine is so loud
No this aint.. What is wrong with your machine is either the spider on the drum has cracked or your bearings are on there way out.. Not dealing with the problem right now will could be fatal... if you need any help let us know i do hundreds of these machines....
Jan 02, 2008 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
351 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
