Question about Lexmark X2470 All-In-One InkJet Printer
Lexmark 2300 Printer/Scanner
I have followed instructions to install a new ink cartridge (ie Lexmark 1), but when I lift the cover the cartridge will not come into the centre in order for me to remove it. What am I doing wrong???
  • tates12345 Sep 27, 2008
    i have lost my cd
  • liz_mcgrath Jan 11, 2009
    how do i put a new ink cartrige into my lexmark x2470 printer
SNAP the cover up...literally....SNAP it up...gently lifting it into place does NOT activate the cartridge alignment. Make sure the power is on...LIFT UP THE LID QUICKLY SNAPPING IT INTO PLACE...the cartridge then moves into the middle..
Posted on Jan 02, 2009
Make sure the power the printer is on when u lift the cover
Posted on Oct 09, 2008
Beat the **** out of it.
Posted on Dec 08, 2008
  • vsmarx Dec 08, 2008
    **** her in the ***
How do i install mt inks
Please follow the steps below on how to install/replace ink cartridges on your model:
  1. Make sure the All-In-One is on.
  2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
  3. Grasp the tabs on the cartridge lids, and then lift the lids.
  4. Remove the old cartridges. Store them in an air-tight container or dispose of them.
  5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges.
  6. Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed.
  7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X1270 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    How to install ink
    Here's a link to the Lexmark website to guide you on how to install/replace the cartridges on your Lexmark printer. http://bit.ly/cevMS4. The printer shown may not look exactly like your printer, however, the steps are the same. But, there are cases that the cartridge carrier doesn't move to the center when you lift the scanner unit. If that happens, unplug the printer from the power source. With the scanner unit lifted, hold the solid white tape you see inside the printer. The other end is connected to the ink cartridge carrier. Slowly drag the carrier to the center to remove the cartridges and install the new ones. Close the covers. Close the scanner unit. Plug printer back to power source. Let it print the alignment page to align the cartridges. Hope this helps.
    Apr 27, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    I can't figure out how to replace the ink cartridge. How do you remove the old ink cartridge and put in a new one?
    Here's an article in the Lexmark website that will guide you on how to replace the ink cartridges on your Lexmark X5150 printer. Just click on this link: http://bit.ly/bKZ15F. Follow the instructions carefully. By the way, in some cases, the ink cartridge carrier doesn't move in the loading position even when the printer is on when you lift the scanner unit open. If that happens, unplug the printer from the power source. With the scanner unit open, hold the solid white tape you see in the printer. Slowly slide the cartridge carrier to the center for easy access. Replace the cartridges. Close the cover, close the scanner unit. Plug the printer back to the power source. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
    Apr 19, 2010 | Lexmark X5150 All-In-One InkJet Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    How do i change the black ink cartridge on a lexmark x2580 printer
    With printer on and connected to computer do the following:
    Open top cover.
    Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
    Wait for ink carriage for taking position in the middle of the printer rail.
    Open cartridge top cover.
    Pull cartridge toward yourself and snap it out.
    Do the same in reverse order to fit new cartridge.
    Remember to remove cello tape strip from new cartridge nozzle.
    Do alignment procedure after replacement.
    Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
    Changing ink cartridge/s
    The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
    Dec 11, 2007 | Epson Stylus CX5800F All-In-One InkJet...
    Lexmark X2470 All-In-One InkJet Printer Logo
    287 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
