Related Tags:
This problem should be removed because:
Problem with Maytag MFI2568AE Side by Side French Door Refrigerator
My freezer has an ice build up. The drawers are frozen and will not move. I tried defrosting it and cleaning it and the ice built up again.
Solutions (1)
Best Solution
OK most refrigerators have 3 parts that operate the defrost and if even one of these parts fail you end up with the no defrost conditions. I cannot find any photos of the defrost heater but can show you the location in this photo description=> MFI2568AEW_Freezer_Section_Parts_Breakdown Looking at that photo shows each part numbered and part listed as 17 is the defrost heater part number=> 67006386 Heating Element or here=> 67006386 Heater also in that photo is the defrost thermostat=> 67006387 Defrost Thermostat or here=> 67006387 Thermostat like before there are no photos. Click=> Defrost Heater and Defrost Thermostat Instructions removal and re-install Instructions How to test a defrost heater click=> Here Now the first thing I want you to do is Force defrost is performed by using your Freezer Display and Refrigerator keypad. Enter the Forced defrost Mode by performing the following sequence of events.
1 Press and hold the Door Alarm Keypad button.
2 Press and hold the Refrigerator Temperature Keypad - minus sign
3 Release the Door Alarm Keypad and wait 3 seconds. Fd appears in the Freezer Display
4 Press the Refrigerator Down Keypad - minus sign Again. Sh should appear in the right display
5 Press again to Force Defrost Fd and Sh will flash in display indicating unit is in defrost.
If you have any problems please let me know here or on my websites HERE Thanks Sea Breeze
water leaking onto floor
Refrigerator was moved to another room to replace damaged wood floor due to break in water line on washing macine. Floor is replaced and...
ge side by side not cool enough even on higher
ge side by side not cool enough even on higher settings
freezer drawer on sub zero stuck
The drawer will not move at all. We recently have had some ice build up on the back of the rails. So I suspect ice and ice maker. Is...
LG GR-349R bottom mount freezer gets heavy ice
LG GR-349R bottom mount freezer gets heavy ice build up in 3-4 days under lower drawer in freezer. L side of fridge near where fridge and...
There is an ice build-up underneath the humidity
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We...
Add Your Solution
MFI2568AES dispensing water slowly
I never had a problem with the water dispenser. The change filter light came on so I purchased the correct filter...
refrigerator does't seem to turn off
I can seem to find my refrigerator off
when was this refrigerator made?
Problems with this refrigerator and now cannot remove the filter. I called and was told to turn off the water supply. I...
Related Topics
- maytag refrigerator
- Thermostat location
- freezer drawer
- freezer alarm
- Maytag performance
- french door
- how to remove keypad
- test heating element
- force a defrost
- frozen display
- Install Heating Element
- french door refrigerator
- remove heating element
- refrigerator door alarm
- alarm keypad
- finding heating element
- maytag defrost
- SH fx50
- removing drawers
- forced flash
Fix-O-Meter
197
197 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
