Question about HP LaserJet 1300 Printer
Paper pickup problem
Paperout problem
    Problem Solver:
  • 14 Answers
Hi
If this if a office printer its bond to have stuff fall into it like staples or paperclips. these things fall under the tray and get stuck underneath the paperout flag so firstly take the printer turn it upside down nb remember to remove the toner cartridge then shake it to get anything loose thats stuck in it.if you have done this and the problem persists then you have to strip the front section of the printer and clean out all unecassary things stuck in there.
I have found alot of things like money, dust and lots of foreign objects stuck under the tray. If you can do it yourself then it is best to get a qualified service technician todo so for you
Posted on Jan 10, 2009
Dear Sir! I have Printer Hp1300 that having probelm , power light contantly ON & printer not picking up the paper?
Posted on Oct 08, 2008
  • 50 Answers
Use the link http://tinyurl.com/ymzx2l to the answer.
Posted on Sep 22, 2008
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Blank pages when printing
Altinis:
Remove the paper tray and look up into the paper pickup area. The roller there is the paper pickup roller. Under the paper pickup roller is a paper double-feed prevention pad. Take a "Q-Tip" dipped in alcohol and clean both the paper pickup roller and the double-feed prevention pad. That should prevent the paper double-feeds that you are experiencing.
Feb 24, 2013 | HP Photosmart B110a Wireless e-All-in-One...
My hp laserjet p2015dn printer is not pickup the paper.
The typical cause of failing to pickup paper and paper jams is worn out pickup rollers. These are easy to replace. The kit of pickup rollers and separation pads can be found here:
http://www.ccl-la.com/catalog/product_info.php?products_id=128
Mar 29, 2012 | HP LaserJet P2015dn Printer
Error 13.01.00 hp 3005
Thank you for contacting FixYa with your printer inquiry.
This is usually a paper pickup error where paper pickup roller is not contacting the paper in the default paper tray or Pickup roller is worn smooth and not picking up the paper.
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding.
Solutions: Make sure the paper size adjuster in the tray (Paper Backstop) is against the paper and correctly set for paper size.
Paper roller slippage - Needs to be replaced. Order a new one. Clean with water or alcohol in the interim while waiting for replacement. Eliminate all the paper dust. Sometimes works.
Part Number: RL1-1370-000CN Paper pickup roller - Picks up media from the paper input tray.
Venders: http://partsurfer.hp.com/Search.aspx?SearchText=Q7814A - HP Parts Surfer
http://www.laserprinterservices.com/parts.html
https://www.partsnow.com/Forms/Login.aspx
http://www.thelaserguys.com/Printer-Error-Codes_ep_42.html
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet P3005n Printer
Paperout error is blinking on printer it is not getting off though i tried a lot
Check the rubber fick-up feet that feed the paper. they may be jammed. they are just inside of the printer at the bottom of the auto feed.
Nov 04, 2010 | Panasonic KX-P3196 Matrix Printer
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Jul 09, 2010 | Canon Office Equipment & Supplies
IAM USING HP DESK JET F2100 PRINTER MY PAPEROUT LED IS ALWAYS BLINKING AND NOT PRINTING
Possibly it either does not have enough paper in the tray - some printers require about half an inch of paper to work. Sometimes also the switch or feed on the paper try gets stuck, look inside to be sure the paper can feed properly onto the rollers, some printers have sort of a plastic piece that is spring loaded and moves, also look for a switch that may be stuck or if there is any tiny piece of paper that may be inside holding a switch open.
Oct 26, 2009 | Office Equipment & Supplies
Paper won't feed
More than likely you pickup roller is dirty.
You can try to clean to see if that helps.
If that fails, then replace the pickup roller.
Below is a service manual that will show you how to remove and clean the pickup roller and how to replace it if necessary.
LJ1020 Service Manual
  • Pickup roller RL1-0266-000CN 50,000 pages Affects paper pickup
Sep 04, 2009 | HP LaserJet 1020 Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 1300 Printer Logo
123 people viewed this question
Ben Johnson
