Question about Olympus Camedia C-5050 Zoom Digital Camera
Olympus C5050 I droped my C5050 camera, the zoom lever came away allowing the shutter button to fall out how do I fix the zoom lever back in place or if needed where can I buy a new zoom lever and how much would it cost
    Problem Solver:
  • 8 Answers
That's a crying shame.  I believe that spares are no longer available for this unit (which is, IMHO, one of the very best prosumer digitals ever built).
Your best bets would be to take it to a local camera service center, or, to look on eBay for a used C5050 or C8080 (8MP with most of the same capabilities and some improvements, but, not quite as good an aperture) for a very reasonable price in good condition.
I know that's less than ideal, but, after a great deal of research on a similar problem with my C5050, that's where I ended up.
Posted on May 30, 2009
Agent Allan
  • 480 Answers
SOURCE: Zoom lens not working
Hey cjk1234,
You can replace the lens on the camera through a authorized service technician, but often with digital camera repairs the cost of the repair exceeds the price of the camera. I would have the camera looked at by an authorized service tech.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Apr 25, 2008
pishta68
  • 579 Answers
SOURCE: zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Posted on May 11, 2008
pishta68
  • 579 Answers
SOURCE: How to replace LCD monitor/screen in an Olympus C5050 camera
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
Posted on May 12, 2008
pishta68
  • 579 Answers
SOURCE: Olympus C5050 lens
remove the 11 screws that hold the clamshell body together and remove the 4 screws that hold the plastic lens assy onto the chassis. Once you get the screws loose, you need to release the 2 ribbon cables that go from the lens to the camera chassis. When these are released you can pull the lens out far enough to get to the 2 screws that hold the CCD board to the lens. Once these are removes, the lens can now be pulled from the chassis. now remove the 3 screws that hold the lens assy together, they are all in the same direction and the one screw on the side that holds the lens sensor clip on. once these are all removed, carefully pull the 2 ribbons through the outer case while lifting the outer case straight up. Now you have the bare lens assy. It is in 3 pieces. The outer part and the inner part remain on the same plane, while the middle part that has the gear on it twists counterclockwise as you look at the back of the lens. If you cant twist this piece, your lens is jammed and youll have to work to get it off. Normally the lens can be retracted by turning the exposed drive gear on the lens assy, but it is very stiff, you can work it back and forth finding the rough spot and maybe work it out, but if the lens was compressed without motor power, you probably knocked the inner shell out of its helical track, a,nd now the guide pins are buried into the relatively soft plastic outer shell. It is a very labor intensive job but it can be done if you have a worthless camera and are not afraid to give it a go. you can sometimes buy complete lens assy's on Ebay for 50.00. I have fixed about 3 of these but Im on one now that is really frozen, maybe too far gone.
Posted on Jan 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: Sometimes my Olympus C5050 keeps switching off and
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Oct 13, 2009
Can I update firmware on an olympus camedia C5050z camera ?
There has never been an update for the firmware of the C5050 zoom. On Olympus they only offer some updates for Mac and Windows, to improve connection (driver) and a RAW plugin.
May 02, 2014 | Olympus Camedia C-5050 Zoom Digital Camera
Can someone zoom while taking videos?
Yes you can. The Olympus SP600UZ can definitely zoom in to the subject not only in still but also while taking videos. The same lever(can be found on the location of the shutter button) that you use for zooming in while taking still pictures, should be the same thing that you access to zoom to your subject video-wise
Dec 26, 2010 | Olympus SP600UZ Digital Camera
HI MY ZOOM LEVER ON MY C-5060 HAS COME OFF WITH THE SHUTTER BUTTON. I CAN SEE THAT THERE ARE THREE LITTLE PLASTIC SUPPORTS BROKEN THAT HOLD THE ROUND LEVER ON . IS THIS EXPENSIVE TO GET FIXED? I JUST...
hi,
you just try this ,first cut plastic picise size of the pins ,may be there is west calculator's plastic is best for it, and fix it properly by using plastic solution ,like FAVI QUICK just try this carefully,
hope you are understand ,
Aug 31, 2009 | Olympus Camedia C-5060 Wide Zoom Digital...
May 06, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Shutter button stuck
Some have used compressed air, blown directly into the button. this should dislodge anything that is holding the button down. Also check and see if the button is cocked in the body, you can pry it back into position and it should pop back up. It is a 2 position switch, first detent is to hold focus and bottom out is shutter release
Nov 25, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Olympus C-750 shutter problems
Changing the firmware won't change anything. The micro switch may be stuck in the on postition. If you are familiar with micro circuits, you could get the switch from Olympus or USCamera.com and replace it. Or, send the camera to Olympus or an Olympus authorized shop.
Apr 16, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Olympus Camedia C-5050 Zoom Digital Camera Logo
137 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
