Question about Furuno GP31 GPS Receiver
Furuno GP-50 Suspect that your GP-50 suffers the same fate as the newer GP-31 etc . The display module is flow soldered onto the circuit board with 44 wires. I think that vibration causes these to break and you end up with dead segments and/or a completely dead screen depending on which wires break first. If you find out the postage to UK I'd take the unit off your hands just to see if that is the case. I'm currently running a GP-31 with a dead screen, I'm simily using the NMEA output to drive the free PC plotting software 'Seaclear'. Ian
4 Suggested Answers
  • 4 Answers
SOURCE: Gps
Hi fire1961,
Downloading data from my FURUNO GP-30 gave me no problems. But it took me long time to figure out why I coudn't upload waypoints and routes to the GP-30 via the serial port in my ThinkPad T30.
I tried nearly everything tested the cable, tested a lot of different software and even wrote a little c-program to communicate with the serial port. I also tried a serial-to-usb converter with no results. Then I stumbled over this RS232 Tutorial. According to this - serial ports are not just serial port but can be divided into three general categories:
The types of driver ICs used in serial ports can be divided into three general categories:
* Drivers which require plus (+) and minus (-) voltage power supplies such as the 1488 series of interface integrated circuits. (Most desktop and tower PCs use this type of driver.)
* Low power drivers which require one +5 volt power supply. This type of driver has an internal charge pump for voltage conversion. (Many industrial microprocessor controls use this type of driver.)
* Low voltage (3.3 v) and low power drivers which meet the EIA-562 Standard. (Used on notebooks and laptops.)
Then I installed the waypoint upload software to my ten years old Compaq Presario and suddenly I could upload routes and waypoints but only via the on board serial port. The serial-to-usb converter didn't still work.
So if people experience no result trying to upload data to these old GP-30's from their notebooks and laptops. Then I think it could be a matter of these Low voltage ports not are able to provide the FURUNO device with enough voltage. See the above RS232 Tutorial.
Best Regards
Lars Erting
Posted on Sep 01, 2008
TechnoMarine
  • 132 Answers
SOURCE: May I plug-in the FURUNO M-1623 Radar (by NMEA) to
There is no conceivable way this would work.
Posted on Jan 13, 2010
  • 111 Answers
SOURCE: We need the specifications of the cable required for gp 31
A power cable for an RD-30
Posted on Jan 22, 2010
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
Furuno GP-1800 GPS/Plotter switches on, display has only lights otherwise blank.
Try pressing the Brill or Tone key. Use the up arrow to increase Brill and the right arrow to increase Tone. Otherwise, you have an internal board failure and it will require service by tech.
Jan 27, 2014 | Furuno 2.2kw 18" Radome
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
Screen on GP 32 is washed out. Where can I get a new display
Contact your local Furuno dealer. That system uses the popular RD-30 display unit and should be rather avalible.
Sep 26, 2009 | Furuno GP32 Gps 4.5" Display
Manual
http://www.mapsunique.com/ev/special-inst/furuno-30.htm
Here is a site that knows something about it. and to find where to buy one google it.
Sep 07, 2009 | Furuno GP31 GPS Receiver
18'' radome ?
no way no way no way sorry
Dec 19, 2008 | Furuno 2.2kw 18" Radome
I've just bought a boat with a furuno gp 31 , no user manual .is there somewhere I can download one thanks.
Hello!
You can download one here:
http://www.furunousa.com/Furuno/Doc/0/5OS1KKAL2OP434ND790LNUEPEB/GP31-GP36%20Operator%27s%20Manual%20%20k.pdf
Copy the entire link into your browser and you should have it.  It is in PDF format, so if you need a PDF reader, go to www.adobe.com and get one for free.
Hope this helps,
Ken
Dec 06, 2008 | Furuno GP31 GPS Receiver
Gps
Hi fire1961,
Best Regards
Lars Erting
Aug 03, 2008 | Furuno GP31 GPS Receiver
Furuno gps gp 32
The only place to get that screen is through a Furuno authorized dealer. The unit is sealed and gas filled to remain waterproof. You're best bet would be to send the unit in to Furuno for repair. You wont save much doing it yourself because the cost of the screen makes up most of the cost of the repair. They will also make sure that all the software is up to date for the new WAAS satellites that recently went on line.
Have you tried adjusting the contrast? On that model I believe you tap the power key while the unit is on and you will see 2 sliding scales on the screen, one for brightness and one for contrast. Up or down arrows select the scale and left or right arrows adjust it. If the contrast and brightmness aren't tied into the power key on that model, they're somewhere in the set up menu.
If adjusting the contrast doesn't help then the screen has most likely failed. This is commonly caused by old age, however repeated exposure to extreme heat or cold can cause premature failure.
Jan 25, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 GPS Receiver Logo
78 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
