Compaq v3155 i have compaq v3155...problem is wen i switch on that,it does nt get switched on...only the lights on the keyboard come..s it mother board problem...?? wat shall i do for that??
  • dhruba197 Sep 22, 2008
  • 78 Answers
Make sure the monitor is connected properly to the CPU cabinet from the back.
Posted on Sep 24, 2008
Hp compaq nx7300 laptop problems are any word type give wrong input command. pls solve my problems? thanks & regards ravi ..
hi there, i was replaced my hp Compaq nx7300 laptop's keyboard but its not working what else could be wrong can you give any hints on mother board repair b caz iam also hard ware engineer
Mar 23, 2011 | HP Compaq NX7300 (413554-B31) Keyboard
Everything ok yesterday and at least the last two years. Today switch on (several times) green, blue orange lights come on, nothing on screen, then everything shuts down.
Sounds like Maxim 1987 chip needs resoldering onto mother board. There's many entries on Google that tell you how to do it, but it's a hard fix for a non expert solderer. Pressing down on the right hand side of the keyboard as you switch on will often allow the laptop to start up (temporarily). GOOD LUCK!
Nov 25, 2010 | Compaq NC6000 Notebook
Intel mother board power light is on... but processor not working.. when switch on my cpu. the mother board powerlight displayed.mother fan is only one time run for sec.. processor not on
This is was with me too. I know how to fix it. Remove all cables from your cabinet, i mean like keyboard, mouse, moniter etc. Remove your ram too. Then press your power button from 30 seconds. wait for 10 mins plugin all cables and turn it on. Hope it works for you.
Best of luck.
Jul 22, 2010 | Intel D945GCCR Motherboard
There is sme problem wh ma laptop wen i am
If the screen shows a picture but very faintly, the inverter is either not connected properly or faulty.
If there's nothing on the screen at all
1) Your screen is either not connected properly or faulty.
or 2) *********** board has a fault.
or 3) Your graphics card/chip has a fault.
You can connect your laptop to another screen using the VGA port on the back. You have to switch to the spare screen using the keyboard, usually Fn and another key. If the spare screen then shows a picture, *********** board and graphics card are OK, your screen is at fault or not connected properly.
Checking the connections to both the inverter and screen will require dismantling you laptop. If you go about this, ensure all power, including the battery is disconnected.
Apr 26, 2010 | HP Compaq Presario V2000 Notebook
Only part of the keyboard types
hi this is basha ..
my pc compaq motherboard support. i last drivers. i want to know vga drivers or mother board model ,,, how can i find it both.
Apr 02, 2010 | Compaq Keyboard
My Compaq Presario v2000 laptop does not power up after pressing the power on switch. It all started whenever I hibernated it. But it worked after several attempts. Now it has become dead. Can you help?...
Generally this type of problem arises due to Battey. But in u r case it appears like a Mother Board Problem.So u better to visit nearer HP/compaq Service Station u can extende warranty for another year if ur previous extended warranty expired within 6 months...there is a provision in HP Customer Support.
Apart from this You can buy third party Mother boards compatible for V 2000 in other Laptop Acessories store
Jul 08, 2009 | HP Compaq Presario V2000 Notebook
Need help with motherboard power connection wiring.
i have no mother board cd then system is formatting is not possible please help me i want drivers cd
Apr 11, 2009 | Compaq Computers & Internet
Compaq Presario v5000 desktop
Is there a power switch on the back of the power supply which is not on? Make sure the power cord is good and plugged into a good power source. Do the fans run inside the system? Is the fan for the power supply working? If not the power supply could be bad. You can purchase a power supply tester to plug the mother board connector into to verify the operation for about $15.00. Do you see any lights on the mother board and the Hard Drive light flickering? If you do and your Key Board lights are on your video controller or monitor could be setup wrong or defective. If the power supply tests good then you need to test the memory and CPU. You could also carefully remove all boards except the video card, mother board and memory and see if it boots up.
Mar 30, 2009 | Compaq Computers & Internet
On/Off power switch will not turn on. Compaq laptop which usually has this problem but seems to always succeed in shifting from off to on if I give the power button a little bit of pressing to the left...
I've seen several of these. All have been the connector. On the bottom of you on/off switch is what Compaq calls a button board. This board if OK but it plus into a connector on the mother board. If you look at this connector closely with a magnifying glass as you attempt to remove the button board you'll notice that the connector is coming off the mother board. The pins for this connector are almost as thin as a human hair. I don't know of any way to repair this. HP is only illing to sell a new mother brd. Good luck.
Nov 28, 2008 | HP Compaq Business Notebook NX9010
How do i remove the keyboard
Use this link for a video tutorial from HP.
In the list you will find a choice for keyboard.
http://h20181.www2.hp.com/plmcontent/NACSC/SML/results.htm?SID=384511&MEID=F2DAF231-84E4-4AE7-BE71-BB1CA8A20D6A
There are other videos listed there as well that may be usefull. Hope this helps.
Oct 30, 2007 | Compaq Presario V5102NR Notebook
Computers & Internet Logo
David Payne
David Payne
