Question about Kenwood XD-655 CD Shelf System
Error Message " PROTECT"
Dear Sir/ Madam,
My Kenwood XD-655 has gone to protect mode. cannot power on or off.
please get me a resolution how to fix this issue.
appricate if you can send this ASAP to the follwing email address
Thanks
Amal
amal@jithpl.com
  • bartvanschoo Jan 10, 2009
    When I turn on my XD951 it automatically goes into "Protection" mode
    How can I solve this issue?
    Please let me know as soon as possible.
SOURCE: Sharp Stereo- Protect Mode??
Try plugging in a pair of headphones. I tried it without the speakers connected and since it found the headphones and they were OK the system came out of protect mode.
Posted on Oct 27, 2008
SOURCE: Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Posted on Jan 22, 2009
SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
Posted on Feb 28, 2009
piyush dixit
  • 136 Answers
SOURCE: MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Posted on Dec 09, 2009
SOURCE: kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
Posted on Feb 05, 2010
How do i take off proetect mode off my KENWOOD XD-A5 mini component system.
https://www.techwalla.com/articles/how-to-turn-off-protect-mode-on-my-kenwood-stereo-receiver I would suggest working through the following steps.
Apr 09, 2017 | Kenwood Audio Players & Recorders
How to reset in PROTECT MODE on a SONY CD-BA200?
Check the belts on the cassette players Had a similar problem some time ago and it was cause by a broken belt on the cassette player
Apr 21, 2012 | Kenwood XD-655 CD Shelf System
My Kenwood KDC-MP142 in protect mode. is there a reset button??
My kenwood is stuck completely in protect mode. I ve everything listed and it wont come out of it. So should i assume the unit has gone bad?
Oct 20, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
When i turn on , the display is" PROTECT " KENWOOD XDA55
make sure the speaker wires aren't shorted anywhere.....a short normally activates protect mode on most stereo systems.
Oct 22, 2010 | Kenwood XD-655 CD Shelf System
I get a message Protect. All other controls are
Usually the protect is a safe mode to indicate that your set is unsafe. Starrt by checking the speakers, speaker wires for shorting. detach the speaker lines and power on the set for confrimation. check in power/auxially circuits in the set. it is possible that your mechanism drive / audio output drive Ic's could have shorted. Most of these cirrcuits have an error detection of higher current to cut off power and issue a protect warning. so discoonect the IC power to confirm. Hope this helps. Good day
Jul 12, 2010 | Kenwood KDC-MP435U CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
May 25, 2009 | Kenwood Car Audio & Video
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
Mar 08, 2009 | Car Audio & Video
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Nov 21, 2007 | Kenwood XD-655 CD Shelf System
Kenwood XD-655 CD Shelf System Logo
128 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
