Question about Panasonic KX-T7730 Corded Phone
How to record miscall on Panasonic kx-t7730
Please let us know how to record a miscall or un-answered calls on panasonic kx-t7730
  • 3 more comments
  • jjacalan Sep 23, 2008
    Our system is PABX. It was previously programmed to record the miscalls in button No. 11 . When I came to the office yesterday 11 has a red light which indicates theres a miscall, however, the telephone number is not shown only the date. Please let me know what should I do so that it will display the number not date.
    Thanks,
    Joan
    hello cnavarro,
    when i press Prog then button no. 11 it says CID INDICATION. what to do next?
    thanks,
    jjacalan
    when i press prog it says PITS-PGM NO? -> then i press no. 11 then it will display CID indication when i press the button navigator either left or right, up or down it will not display show name, number, date and condition.It will just display CID indication and i can hear 2 beeps.
  • jjacalan Sep 24, 2008
    hello carl,
    thanks a lot for your help and for solving my problem.
    regards,
    jjacalan
  • jjacalan Sep 25, 2008
    I just press prog -> No. 11(CID Indication) -> No. 1 then the Co. Button(Main Line). Then it helps, it records miscalls now.
    Thanks a lot, you fixed my problem....
  • Panasonic Master
  • 2,460 Answers
It depends on your phone system.
If you have a TA system it requires 2 or 4 CO (buttons with lights) buttons. Personal CID Log is
6 for indications and 7 for selection. Group is 96 and 97. You don't have to have a SELECT button but it helps.
If you have a TAW or TDA system you only need one button per feature because the navigator key works as a selector button. The code is 54 for personal and 54 plus the ICD group for system.
The sequence to program these buttons is PROG button CODE store
Carl
Posted on Sep 22, 2008
  • 2 more comments
  • Carl Navarro
    Carl Navarro Sep 23, 2008
    Thwy're ALL pabx's. You probably have a TA. Press PROG and the 11th button and read the dispay. If it says Group Call Log, then it is storing up to 300 of the last calls. Use the gray button on the bottom to select between the 3 or 4 displays...name, number, date, answered
  • Carl Navarro
    The gray navigator button on the bottom moves between the data. Press it left and right and you will show NAME, NUMBER, DATE, and CONDITION.
  • Carl Navarro
    Whoops, go back up to that original answer. The part about needing a selection button. On an 824 you need it.
    My system has 12 as CID C Indication and 11 as CID C Selection. You press the CID I button and while the info is displayed, the selection button steps through the 4 steps.
    Carl
  • Carl Navarro
    Carl Navarro Sep 24, 2008
    So did you already have a CID Selection button or did you have to program one?
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
I need to delete the message on my panasonic answering machine KX-T7730
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Apr 25, 2012 | Panasonic KX-T7730 Corded Phone
Telephone Panasonic KX-T7730. Taken over in a school office and phone has an outgoing message saying "Please press 0 to speak to someone" This message was recorded by previous member of staff. ...
Let's pretend that this is a TA-824 system with DISA and it's answering all phone calls. It's not likely that you can do much of anything unless you know what system the phone is connected to and have the manual and ability to do programming. With a bit of reprogramming, you can make the system perform like a regular system.
I'd suggest a call to the Panasonic service company.
Carl
May 18, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 does this phone have answer machine?
try using the call forwarding feature, you can forward it to your cellphone.
Jul 03, 2008 | Panasonic KX-T7730 Corded Phone
What is the code to record a welcoming message
what system are you using? is it a mailbox or a company greetings?
Jul 01, 2008 | Panasonic KX-T7730 Corded Phone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic kx-t7730
Hi this is normally a programmable control, operating only when the power is ON,...so try to disconnect the power and operate it
or else, reprogram it by using the manual...
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
954 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
