Question about D-Link DIR-625 (790069292637) Wireless Router
DIR-625 Blocking DWL-G510 connection
I had my wireless network working for my 10 years old computer on the 3rd floor. My Wireless router is in the basement along with my 2nd computer. I just brought a new computer to replace the 10 years old one. So I remove the network adapter from old comp and put it into the new one. The drivers were up-to-date and installed correctly. I see connectivity bars and entered the correct password. However the connection process never reaches the point of acquiring ip address. It just stay at trying to connect and never connect. I reinstall every drivers, move the adapter to another PCI slot, reboot wireless router, checked firewall connection. This computer does work for wired connection.
I did notice that the router is BLOCKING the TCP connection from my computer. The weird part is why does it only block this connection, but for my other wireless laptop it worked. Also this adapter worked for my old computer but not new one? I read other forums here stating that the router may block some MAC adresss. Well how do I unblock it? I thought it was suppose to be plug and play and if you enter the correct WPA key, (like how I do with all my other wireless) that it should work.
Also I noticed that the Dlink connection wizard has error for the new computer and doesn't open. So I used windows wizard to connect wirelessly.
Computer Spec:
Asus P5N-MX mobo
Dlink DWL-G510 wireless (rev. B)
Intel Dual Core E5200
Window XP service pack 3
Thanks,
Mike
  • shendriex Dec 13, 2008
    having same issue; laptop connects fine to dir-615, but another xp-home pc with xp-sp2 that connects to dir-615 with dwl-G510 card will not connect to the router. Have all updated firmwire! Any suggestions. Protocol is WEP with shared access on key 1.
  • Anonymous Dec 23, 2008
    I have the same problem. I can connect wirelessly with two computers but then my laptop is blocked when checking the logs. However, if I turn off one of the computers, all of a sudden, my laptop can connect. So I was thinking that maybe the dir-625, can only support a maximum of two wireless connections. I have checked in the settings and can't find a place to raise that number, even if that is possible. Can anyone confirm if this is the answer?
    P.S. For the solution #1, I have the updated firmware and drivers, and mac filtering is off. So that didn't solve anything.
    Problem Solver:
  • 19 Answers
1) First you need to check if the router is blocking mac address. Login to the DIR-625 by typing 192.168.0.1 on the address bar of IE.
Use admin for username and leave password blank or type in your password.
Go to Advance Tap, on the left click on Network Filter. Select Turn Off Mac filtering, click on save settings. wait for your to reboot. If that doesn work try option tow below.
2) What you need to do is Upgrade to the latest firmware on your router (Resolves 99% of all problems). Make sure you download the right firmware for there are two version of the DIR-625 ( Rev. A & Rev. C).
You'll also need to make sure you have the latest driver for the adapter since you have a newer computer.
Posted on Oct 03, 2008
My DWL-G510 does not see my network. It sees my
I feel what you might need to do is go through the settings in you router one more time,192.168.1.1, and make it only g and b, sometimes when you enable the n it does not play nice with lower speeds. also, you might want to disable your security features for a bit and then try. also make sure the router is broadcasting the ssid
May 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
The device manager shows that the D-link Airplus G DWL-G510 is working properly. I have XP - SP3. But when I try to set up the network, it says that media not connected and ti=o check that the wireless...
Are you trying to connect to the wireless network ?
You are using windows XP computer. and you have D-link adapter.
In case of windows XP computer there is built in utility to connect to the wireless network. and also you have Dlink utility to connect to the wireless network.
It will be better to use the Windows utility to connect to the wireless network.
Search for the wireless network and you will see your wireless network. I believe you have the wireless router.
Apr 27, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
Will not connect to my network. PC sees my
have you manually entered the key code? did you add the device to your routers system?
Feb 04, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
Need updated drivers
If your looking for driver's, the best place to look is the manufactureres website where you can usually find the latest version
Feb 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
I'm trying to connect to my wireless network using the d-link Airplus G DWL-G510. I can't get a connection. In the Site Survey is shows about a 50% but won't connect. My Wii uses the wireless router and my...
Ah...found it!
I think that with XP service pack 3, it caused a problem with the wireless card driver.
I just installed the latest driver, and it connected for me without a problem. Here's a link to the driver:
http://www.dlink.com/products/?pid=DWL-G510&tab=3
Hope this helps!
Jan 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
D-Link DIR-625 can not broadcast wireless continously
LOOK AT BACK OF LINK BOX FOR A SMALL HOLE WHEN FOUND TURN POWER OFF ON BOX PUSH TIP OF PEN INTO HOLE THEN TURN POWER BACK ON THIS WILL RESET MEMORY
Jul 19, 2009 | D-Link DIR-625 (790069292637) Wireless...
DWL-G510 cant find network
please, is there anybody who can help me with the setup cd(installation cd) for d-link airplus dwlg510.
Jun 26, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
Use with dwl-2100ap
What you need to do is configure the dwl-2100AP. You need to login into the repeater's configuration page and go to Home tab, click on wireless on the left. Select AP Repeater under Mode. A new screen will show up. Click on the scan button to see if your router's signal is being picked up in the box. Just select the signal if you see it in the box and put in your security info if you have one.
Sep 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
May 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
514 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
