Question about Dell InspironTM XPS M1210 Notebook
M1210 when i try to boot my laptop an error message show tat the amount of system memory has changed.if you did not change your memory... to resolve this problem ,try to reset memory
  • 97 Answers
Try to replace the memory
Posted on Sep 22, 2008
First i got a error message as "memory unsupported please update dimm1".After that i moved the ram to slot 1 after i restarted another error message showing"battery voltage is low ".what is the exact...
these can be related as the main battery on the motherboard is need to retain cmos setting when a system is unplugged from a/c power for extended periods of time.
so the loss of cmos would prompt you about certain components including amount of memory(pending no changes in memory amount/ slot location as a single chip unit must have the mem in slot 1). there is a round 3.0 volt battery that once reports bad, should be replaced. start there and see if you get any other errors. as there could be a problem with the powersupply or motherboard if that doesn't resolve it.
Jul 08, 2014 | Dell Optiplex 755 Desktop Desktop Computer...
I have a v-epc-001 and when I turn it on it just shows wireless book and a progress bar with 'loading device drivers' underneath it...it never boots to windows
Few computer problems are more frustrating than a laptop that refuses to boot, as troubleshooting becomes infinitely more difficult when you are unable to get into the operating system. By understanding the common causes of laptop booting problems, you may be able to spare yourself the cost of paying an electronics store by resolving the issue on your own.
Laptop computer
Error Messages
If a laptop is unable to boot, there will usually be an error message giving you some idea of the problem's cause. Read this error message to know where to begin in the troubleshooting process. Some common error messages seen on laptop computers during the booting process include "NTLDR" messages, which deal with the operating system, and messages relating to the hard drive and the power supply.
Identifying a Software Issue
If a laptop has trouble booting and displays error messages generated by Windows, the cause is often a failed driver installation or other change that rendered the computer unstable. This type of issue can often be resolved by starting Windows in safe mode, then using the System Restore utility to roll the computer back to the previous configuration. If an external peripheral was recently added to your laptop, such as an external DVD drive, try booting the laptop with the device disconnected, then reconnecting it once Windows is fully loaded.
Identifying a Hardware Issue
Random booting issues on a laptop--those that seem to come and go with no explanation--are often caused by a problem with the hardware. Other symptoms of a possible hardware issue include a system that does not get past the POST screen (the initial monochrome screen displayed when the unit is turned on), or an error message containing the word SMART (this refers to an internal health monitoring system used by hard drives).
Identifying a Heat Issue
For all electronics, heat can be a killer. Heat-related issues can be caused by using the laptop in an unsafe way (such as by putting the laptop on a surface that blocks the air intake port), or by dust building up inside the cooling system. An unacceptable level of noise emanating from the cooling can generally signify that the cooling system needs to be cleaned in order to prevent a more serious issue. If a laptop has a booting problem that only tends to arise after the machine has been in use for extended periods, heat is likely to be the cause.
Prevention/Solution
Do not neglect your laptop's power supply. Laptop power supplies are often quite fragile, and are susceptible to damage from heat (exacerbated by being trapped under a desk or chair) as well as damage to the shielding surrounding the cable. Problems caused by a faulty power supply are often not instantaneous; it can take time for a power-related issue to become evident. To avoid booting problems that may be caused by a power issue, replace your laptop's power supply at the first sign of physical damage.
I hope you find it very helpful. Thank you.
Aug 22, 2011 | ASUS Eee PC 900 16G Notebook
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Blue screen of error with memory dump message and Vertical line
try to use an external monitor, plug it on the system and let it work with it for an entire day, it the problem occurs on the external monitor, it can be the video card, but if the problem doesnt happen on external monitor, its the lcd. try also to go to bios, by pressing F2 when the computer turns on and you see the dell screen, it will go to the bis an let it stay there for hours, if the problem happens in bios, video card is indeed bad. you said you have tried the diagnostics? is it by pressing Fn and power button? if the diagnostic looks fine, its a software but you mentioned you have reinstalled the operating sytem already,so focus on the hardware part. i believe your video card might be intel which is integrated or nvidia,for nvidia, lots of issues for it. so better try the external monitor or go to bios.
Sep 26, 2009 | Dell XPS M1210 Notebook
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Phone memory
change your n70 message memory to memory card.... click on MESSAGE,OPTION,SETTINGS,OTHER,MEMORY IN USE, then change it to MEMORY CARD.. With thats u will be able to send meseges. thanks
Dec 31, 2008 | Nokia N72 Cellular Phone
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
ECS A535 Video Memory
You can only change the amount of video memory if your model has a videocard memory that can be dynamically changed. You're correct that it can be done, but only on specific models of notebooks. :) If you're not able to find it on the BIOS then your model might not be one of them.
Sep 21, 2008 | EliteGroup ECS A535 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Dell InspironTM XPS M1210 Notebook Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
