Question about NEC Versa LX Notebook
Will not turn on and no battery led on.
Hi, my NEC Versa S940 will not start. The battery led doesn't even come on. Very strange as working fine one day and this happens the next. Please offer advice.
Wath is the HDD paswoord for NEC versa S940
There are no backdoor password available but these WEB sites may help.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Nov 10, 2012 | NEC Versa VX Notebook
Nec versa wont boot. the battery was taken out when the screen froze. and now it wont boot fully. wont even go to safe mode or do last known good configuration
try to turn off the pc , remove the cables and/or battery (if it is laptop). Then press & hold the power button for 5 seconds then reinsert the battery and cable.
Turn on the pc , if it did not work, call the NEC tech support at 1-408-844-1100
Mar 29, 2010 | Computers & Internet
My laptop nec versa stopped to work suddenly. I
A questions are to be asked here. Does the laptop work when connected to AC power supply? If yes does the battery charge when connected to AC? If yes does this turning off happen when running on battery too? Please answer these questions so that I can help you with the diagnosis.
Regards,
Sai.
Nov 21, 2009 | NEC Versa VX Notebook
My nec versa s940 won't start up when connected to the mains the battery had previously run down a pink light is on, on the side of it and the blue light on the 'on' switch keeps flashing
remove the battery and see if the system comes on, however unplug the power first and then remove the battery, let it set of 1 min and then plug in the power and try to see if it comes on, and you might also want to check and or replace the memory card (ram) and see if that makes it start up as well. sounds more like a mother board problem, but give that a try and see of those two tricks help you. good luck and it's been a pleasure to serve you.
Jun 23, 2009 | Computers & Internet
My NEC versa s940 battery problem
Replace the battery,
They don't last forever, and do fail over time.
If it works on the A/C mains, this confirms battery needs replacing.
Or re-cell the battery.
Regards
Richard.
Apr 21, 2009 | NEC Versa VX Notebook
NEC Versa Notebook S Series User Guide
Here you go.
NEC Versa VX User Guide
Don't forget to rate my solution FixYa
Thanks!
Mar 01, 2009 | NEC Versa VX Notebook
NEC ultralite SL/25C with not start up batteries(cmos, bridge)new
try to remove the battery and plug into AC.
you can also try to recharge your battery (if it is still working well) for a few hours before turning the laptop on.
let us know.
Feb 07, 2009 | NEC Versa VX Notebook
Battery recharge
Motherboard is possibly bad. Try doing a Google search for NEC Versa LXi recharging board.
Jan 06, 2008 | NEC Versa LXi Notebook
NEC Versa LX Notebook Logo
127 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
