Question about Whirlpool Microwave Ovens
WHIRLPOOL MICROWAVE OVEN GH9184XLQ1 is not heating up displaying F-7 code please advise.
  • roneil4325 Sep 22, 2008
    WHIRLPOOL MICROWAVE OVEN GH9184XLQ1 is not heating up displaying F-7 code what does this code mean.
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
    I would then have these questions:
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
    When does the F7 code occur? About 60 seconds after you plug in the power & set the clock, or some time after you press Start when trying to cook?
    There
    should be a "mini-manual" hidden inside the unit behind the
    control panel or hidden on the left side behind the grille, which is
    very helpful when troubleshooting & testing. If you have that, it may list the trouble codes.
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Panasonic Microwave Oven Stops After 15 seconds - Never Heats
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Posted on Oct 22, 2008
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jun 11, 2009
milten1
  • 1304 Answers
SOURCE: I have Whirlpool Microwave oven Model MH6110XEB-0
with any luck you have just poped the inline fuse,
if you remove the control board you should be able to see the tube fuse up by the fan motor
if not the whole thing will have to come down to reach it
Posted on Oct 14, 2009
Whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Apr 27, 2008 | Whirlpool GH9185XL Microwave Oven
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
The microwave won't heat and the is a "d" aftrer
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 02, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave hood combination, model # MH9181XM, is not heating anything and displays an error code of F7
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Whirlpool Microwave Ovens
We have had this microwave for 7 years. Not had any problems until about six months ago when the volume went way down when you push the buttons and timer, but still heated. Then all of a suddon it does...
Remove the cabinet ... check the door safety interlock switches for proper operation. Most of the time, no heat problems can be traced to the oven thinking the door is open. These switches tell the oven if it is open or closed. If they are faulty ... well ... the oven thinks the door is open and will not turn on the heat.
Make sense?
Thanks for your question today.
Feb 06, 2011 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool microwave MT8066SE does not heat but the display works, and the turmtable goes around. Power is set to 100%.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ruiury
Oct 08, 2009 | Whirlpool MT8066SE Microwave Oven
HI. I have a Whirlpool Microwave (MH6141XKB). It will not reheat the food and makes a louder "humming" sound than normal. Other than that, everything works fine. Please advise. Brent
Brent
The magnatron in your oven has gone out and will need replaced!( This is the device that heats up your food) If everything is working and your food is not getting hot 99.9 percent of the time its the Magnatron or its fuse! The loud humming is also a big clue the MAGNATRON has gone bad!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Whirlpool MH6141XK Microwave Oven
Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
Nov 29, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
190 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
