The coin slot is stuck/jammed on our washer. There are coins in the slots, and the coin catcher has been removed (we thought maybe it was full). I can feel the opening for the coins, but the coin-slot-thing will not go in or out.
  • Anonymous Dec 08, 2008
    I have the same problem. The quarter is stuck, coin slide won't go in or out.
Krazytech
  • 725 Answers
SOURCE: How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Posted on Nov 17, 2008
  • 686 Answers
SOURCE: Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Posted on Apr 24, 2009
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
  • 4 Answers
SOURCE: how do you check if the coin catcher is plugged on
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Posted on Oct 21, 2009
pride applia
  • 232 Answers
SOURCE: change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Posted on Dec 31, 2009
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
How to remove a carousel stuck on a Kodak Carousel projector
No problem! FIRST, make sure the locking ring is in place and tight on the top of the tray. Next, locate the center hub (the hole in the center of the tray fits over it). In the center of the hub you will see either a "coin slot" or a small metal lever. Push the lever in the direction it will move and at the same time lift the tray off the projector. If you have a "coin slot), use a quarter to turn the coin slot until the tray is released. Turn the tray upside down, replace any slides that may have left the tray when it became stuck, and rotate the bottom metal plate until it locks in the locating slot. Turn on the projector and cycle it a few times IN REVERSE without a tray on it. this unlocks the jam in the projector. You should be good to go now!! Good Luck !! Jim
May 05, 2012 | Kodak Carousel 4600 Slide Projector
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
How do I remove as coins stuck in cd slot
hi....
there is only one way to remove the coins from the cd slot.....you needed to go for the service center....there they will disassemble it in few seconds and take out the coins and reassemble it very carefully.....so that your cd player also doesn't get any damages in it....it will cost only very little....
if you are satisfied with my solution then rate for me.....
thank you for using fixya.....
Jul 20, 2009 | Sony CDX-A250 CD Player
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Coin operated washer and dryer
remove the coin slot out remove the slug used to plug the coin slot
Feb 24, 2008 | Washing Machines
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Washing Machines Logo
408 people viewed this question
Top Washing Machines Experts
