Question about Samsung SyncMaster 760vTFT Monitor
Samsung TFT Motior 743x
I have a Samsung motior, and it is only 3 weeks old, but i am getting this weird problem with this monitor, sudenly yesterday the motior while bott up is showing weird lines and colors, the proper color is not coming.
I removed the VGA Cable, an i was getting the proper "Check Your Signal" Picture, with RED Green And Blue Box.
I dont understand what is the problem, How can i solve it.
JMuskovitz
  • 135 Answers
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Posted on Feb 21, 2007
jitenok
  • 151 Answers
SOURCE: vga cable color code of 56v monitor of samsung
visit this site www.jitenok.wetpaint.com there is coads for cable in home page.
Posted on Aug 08, 2008
  • 46 Answers
SOURCE: I have samsung syncmaster 591s monitor. No
try to check out the display driver resolution settings
Posted on Feb 24, 2009
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
SOURCE: Vga cable color code of
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Posted on Aug 03, 2010
Samsung Monitor Model : LS198300NS giving distortion on screen, when I change it with Sony Laptop cable, it becomes ok, but not with a Samsung Cable. What should I do ?
hi
if you monitor is old , it may be due to bad filter caps in the power supply section!
if its not that old then the cable is itself at fault!
Apr 07, 2015 | Coby 20" Flat Screen TFT LCD TV Monitor
The screen seems to be slowly turning white.
More than likely a manufacture defect. If it is not that old; I suggest contacting the manufacturer to get it replaced. Most LCD"s have 1 year warranty, and it's certainly, not weird to see 3 years.
Jul 24, 2010 | BenQ FP71E 17" LCD Monitor
Spray arms won't turn they turn freely by hand and are not clogged
either you are not getting any water in the machine or the main motior is not running. Check inlet valve to see if water is coming into machine.
Feb 25, 2010 | Dishwashers
I have a samsung lcd-tft monitor (syncmaster
call on 01122222222 and take the number or address form yellow pages
Nov 03, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Feb 06, 2009 | Gateway Computers & Internet
Weird characters on monitor, cannot log-in
Well, either the monitor is messed up and trying to display a message like "No Signal" or the monitor is set for a different language.
What happens when you press the menu button on the monitor? Change you make changes?
Nov 18, 2008 | Computers & Internet
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
Whirlpool calypso washing machine
WP HAS HAD A ON GOING ISSUE WITH THIS THAT IS THE REASON WHY THEY REDIGNED THE DRAIN PUMP. YOU NEED TO 1ST DRAIN OUT AS MUCH WATER MANUALLY AS YOU CAN THEN DISCONNECT ALL YOUR HOSES FROM WALL TAKE THE WM OUTSIDE TO DRAIN THE OTHER 3 GALLONS OF WATER YOU CANNOT SEE. TURN THE MACHINE ON ITS BACK THEN USING A 5/16 NUT DRIVER REMOVE 4 SCREWS ON THE BOTTOM PANEL. REMOVE PANEL AND YOUR DRAIN MTR IN ASSESSIBLE. THE PART CAN BE ORDERED AT WWW.REPAIRCLINIC.COM
May 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
1993 GMC JIMMY FUEL PUMP
check your #1 plug and see if you are getting spark my be the distuberter cap or rotor is bad
Dec 23, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
Samsung SyncMaster 760vTFT Monitor Logo
202 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
