SOURCE: I have 3 compressors, all of them refuse to stop
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
SOURCE: pressure switch dows not shut off motor when
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
Testimonial: "Thanks for help, many appreciated."
SOURCE: trouble building pressure
I would check the reed valves in the pump. One of them may be broken.
