Question about Coleman Powermate Powermate 5000W Generator
Powermate 5000 dies after a couple of hours
I purchased a Powermate 5000 about 3 years ago. It stayed in the box until about a month ago when I put it together and fired it up. That was just in time because I've been without power for 9 days now thanks to Hurricane Ike.
The generator was working great until last night when it died 4 times during the night. It seems to run great for about a couple of hours, then it just quits. When I pull the cord, it starts right back up.
Since I started running it, I have changed the oil after the first 5 hours then after every 50 hours. I replaced the fuel filter and spark plug today (even though I don't think they needed it). I drained the tank of gas and replaced it with fresh gas. I thought it might be getting too hot, so I put a fan on it. It still shuts down every 2 hours.
Any suggestions?
    Sergeant:
  • 208 Answers
I just want you to try this.
Take the air filter off
clean the carb bowl.
Take carb cleaner and spray directly into carb.
Check the gas lines that they are clear.
The carburetor.
The problem may be that the carburetor is may be blocked up not letting fuel get through. Sometimes they are very hard to clean and get them to run correct, you need to use a magnifying glass and remove the jest and look at the passages closely, Or get your engine model numbers and id and go price a carburetor. Thats is the best fix.
Thanx for using fixya.
Hope it works.
Bye.
Have a nice day.
Posted on Sep 22, 2008
    Genius:
  • 1,847 Answers
You will need to contact Powermate directly (see below), and give themthe CORRECT model # info that you have there on that Genset.
Unfortunately what you posted above doesn't help out at all as there isNO model # for reference. Certain models are no longer available asthey have been discontinued and only by contacting Powermate directlywill you get the proper Operators Manual.
There should be no charge for this and most likely it will be a PDF download sent by their service dept.
The model # should be found either on the engine decal plate or else on the generator head assy or it's power panel.
Please post me a reply as to finding this solution being the bestresolve to your missing Operators Manual problem by following thecompany references & links below. Also please rate mytroubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Kevin
  • Legin Varghese
    Legin Varghese Sep 22, 2008
    FOLLOW-UP ON POWERMATE 1000 & 5000 GENSET
    A follow-up to my original post here with some added Powermate info
    that hopefully will get you an Operator's Manual (and more) for all your Powermate
    Gensets out there if you follow-up on the info here.
    As you are now hopefully but painfully aware - Powermate has gone
    totally Bankrupt, and is no longer in business as of this past year or
    so.
    There is hope though - as I state below in the Footnote:
    Footnote: It's too late now for all those
    out there that
    unfortunately bought these now still Brand New "unservicealbe"
    Powermate units that won't start for whatever, whether still Brand New
    "NIB", or whether taken out of the box and still not used, and are
    now seeking some kind of service on them (btw it's a sign of the
    present day GOP ran economic woes we are in AND it will only get worse
    - CHINA is going on the very same downward path right now thanks to you
    know who - W!). If you buy anything today "made in China" you better be
    making a GOOD buying decision - otherwise you will be in the very same situation
    you are in now with your Powermate Gensets - as China is starting to
    collapse from within just like this USA economy of ours has been doing for
    the last 5-6 years to no end! All politics aside as well - as blame is
    put where it is deserved in my books and we can only blame YOU KNOW
    WHO! Sorry but true!
    NOW -
    Any inventory stock of their (Powermate) Gensets - that were once formerly sold in the USA & Canada - have been
    totally liquidated out to a company in Georgia I was told, and it was said to be true.
    I was able to get this NEW added info through another source said to be VERY accurate btw - so hopefully it is.
    That Company's name is PRAMAC, and their phone # is 770-218-5430.
    BUT -
    Before you blame me for any false info on that PRAMAC Co, or their phone # read the GOOD NEWS below first.
    The GOOD NEWS is that I spoke with a very close contact inside Home
    Depot (not saying who so don't even ask), and that person gave me some
    very GOOD NEWS for those that act on it NOW!
    Not tomorrow - Not next week - Not next month - and certainly NOT NEXT YEAR!
    DO IT RIGHT NOW!!
    I spoke with my Home Depot Corp contact today (using your dilemma - as
    my own - to get a response) to see if anything could be done from their
    point of view and here's what I was told to do.
    What I was told is that if I bring in my ORIGINAL HOME DEPOT CASH
    REGISTER DATED RECEIPT and speak to the (whichever Home Depot store
    applies here) Home Depot Store Manager there, and explain to them that
    the brand new never used Powermate Genset they sold me (you in this
    case) won't start - they would send your Genset out to their local
    Genset Service Vendor FREE OF CHARGE BTW, and hopefully get it started
    for you.
    Anything more then that - you would be on your own if it was damaged by you or someone else that tried using it.
    Here's another IMPORTANT FACT my contact at Home Depot told me.
    Almost 95% of all the Genset problems found by the Service Center are
    related to the fact that people don't read the OWNERS MANUAL and just
    didn't put OIL in the Genset - as they are shipped from the MFR without
    OIL in the units to begin with!!!!
    And here I thought everybody KNEW THAT!!
    I guess sometimes you just have to ask the OBVIOUS ??'s first huh?
    If you bought your Powermate Genset from other then a Home
    Depot Store then you will have to contact that outlet and see what they
    have to say.
    Best regards to all with the same problems, and hope I helped you out 100% - all political humor/truth aside.
    resolve to your Powermate problem there by following my recommendations
    above. Also please rate my troubleshooting fix as well.
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Where can I buy a wheel kit for a Coleman Powermate 5000 Genterator ?
Do an online search. I bought mine that way years ago.
No, I have no idea where.
Aug 26, 2014 | Coleman Powermate Powermate 5000W...
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
Engine dies
Your carburator is gummed up !
Take the float bowl on the bottom of the carb and spray the main fuel jet out with cleaner, do this to the idle needle valve also. If that don't work pull the carb & take apart & soak overnight in parts cleaner & blow out all ports & orfices with compressed air.
Next time you store your generator with gas in it , use a fuel stabilizer !
Good luck !
Oct 05, 2008 | Coleman Powermate Premium Plus 6250W...
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
NO VIDEO
I have a Samsung 50" plasma, that has been blacking out over the last 6 months. A 9/2005 set. Now its practically unwatchable as it happens 3 times in an hour. Its not heat related - I have a high volume 9" fan activated on TV power on. Turning the set offf/on usually makes it come back for a now short while. Considering to go put it in the back of my pickup and park it in front of Best Buy and discourage Samsung purchases. This is the 2nd Samsung TV I've purchased (the other a 32" tube) I gave to my folks a couple years ago and its gone bad as well. Samsung product may look good, but their video engineers are not.
Jan 19, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Coleman Powermate Powermate 5000W Generator Logo
267 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
