Question about Verbatim VER95327 USB Hard Drive
Verbatim Thunderbird email USB plugin to Vista
When I plug my U3 stick. I get an authorization saying. Unidentified program want to access your computer.
with this text: Thunderbird U3 start.exe
Unidentified Publisher
After I get out of hat screen there is another that pops up saying
! Thunderbird for U3 cannot be started you may have to reinstall to fix this issue. ( ERROR: The program could not be found: \thunderbird\thunderbird.exe)
I don't have any problem plugging this in to most computers except when I do it on a borrowed desk top. My own vista computer excepts this . What do I need to do to make this work?
Thanks Brett
ps My email is brett.frederickson as I am on a borrowed computer now and need to access this.
  • brettro Sep 22, 2008
    Thanks Brett
  • Verbatim Master
  • 2,045 Answers
Have you tried to re-format this USB?
Posted on Mar 27, 2017
Chinthakaj
  • 416 Answers
SOURCE: verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Posted on Jun 10, 2009
  • 13 Answers
SOURCE: 1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Posted on Aug 08, 2009
lserni
  • 466 Answers
SOURCE: Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Posted on Oct 27, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
bob_computer
  • 3153 Answers
SOURCE: I have plugged in my new Verbatim 160Gb external
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive
Posted on Nov 21, 2009
I am operating with windows vista home premium. I want to know how to save items in certain folders onto the Verbatim stick, can u give me a Step by Step, derekjkeough@yahoo.ca
Plug it into the usb port and go to 'my computer' there you will se the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Feb 15, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
When I plug my new SanDisk 2GB Cruzer USB 2.0 Flash Drive into my computer, it says the drive is read only- How can I fix this?
If this is the U3 SanDisk Cruzer....U3 drives present themselves as two devices. One of them appears as a read-only CD drive that contains all the **** programs and the other is the writeable USB stick part. It comes with two partitions on it, one for data, and the other called "U3 Partition" which is read-only.
Mar 02, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to format a verbatim Store "n" Go part# 95401? I am looking for the software for reformatting it and can not find it.
  1. If you’ve used the device before, make sure you’ve gotteneverything off of the drive you need. You’ll be reformatting it. (Theapplication may have an option that allows you to keep the data – Idon’t remember – but better safe than sorry.)
  2. Plug in the drive – the U3 launchpad will load. You can close theU3 tour program and whatever main window pops up if you like, but leavethe U3 launchpad icon in the system tray enabled (i.e. don’t exit thelaunchpad application entirely).
  3. Download SanDisk’s U3 Launchpad Removal Tool (opens in new window) – as the site says, make sure the USB device is plugged in and Launchpad is still running.
  4. Run the tool, and choose the option which completely removes U3 and formats the drive.
Voilà, you now have a regular old USB drive which you can break in any way you want.
(NOTE: If the SanDisk tool above doesn’t work for you, you might try the uninstall tool from u3.com – I had no trouble with the SanDisk tool, but I can only speak for myself!)
Jun 20, 2009 | Computers & Internet
U3 Flash Drives - What Are They and How to Remove U3 Software if Desired
U3 Smart Drives are regular USB flash drives with a twist. Programs can be installed on them and the data from those programs will travel with you. In other words, U3 Drives are computers on a stick. Although the technology is relatively new (the company started in January 2005), there is a wide variety of programs that can be used on these supercharged USB drives.
One of the most important advantages of using a U3 enabled flash drive is the ability to take your documents, photos, email, address book, favorites, webpage logins, and more with you wherever you go.
Of course you can backup all these files on a normal USB flash drive or other removable device, but the advantage of using a U3 drive is the programs along with the data are on the USB drive. This means you'll be able to work on a report, view photos, look up an email address, and more simply by plugging the device into a computer and pulling it up. You dont necessarily have to take a laptop with you anymore to get your work done.
You can't make a "normal" USB flash drive into a U3 enabled drive. The U3 system software is pre-loaded on the drives and cannot be added to a normal drive. When a U3 drive is plugged into a computer, it creates two drives. One is a CD drive with the system software on it and the other is a removable drive that you can use to store information.
Oct 18, 2008 | Computers & Internet
OLIN USB 2.0 2GB Memory Stick
If the drive has u3 on it, you need to run the u3 removal tool to remove out the non compatible U3 software from the drive so that it won't pop up on vista.
http://www.u3.com/uninstall/
If your drive doesn't have u3 on it, you could have a driver issue on your vista machine.
Apr 30, 2008 | Computers & Internet
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim Store n go 4 GB USB HD Drive
IF IT HAS U3, YOU NEED WINDOWS XP...AT LEAST TO ADD THE VISTA UPDATE FROM http://www.verbatim.com/downloads/U3/u3updater_verbatim_us.exe
IF NOT THEN YOUR DRIVE MIGHT BE DEFECTIVE OR ONE THAT YOUR OPERATING SYSTEM CANNOT USE
Feb 21, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Sandisk4Gb Cruzer
explain more. Is U3 launchpad on the USB disk?? explain details and I'll see what I can do for you...
Cynthia
Jan 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Is the account that your tying to access the drive with an Administrator account? If not, Log in as Administrator and try to access the new drive. If you ARE using Administrator privileges on the vista machine, the problem lies in the U3 smart driver. Try downloading and installing the drivers for the XP SP2 os on scan disks website, If vista rejects the install package off of the scan disk website, let me know and i'll extract the drivers and build an install for them for you.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Verbatim VER95327 USB Hard Drive Logo
41 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
