Question about Acer Computers & Internet
Motherboard dosent working
My computer is acer desktop.problem is doesent come signal from motherboard.processor fan other fan working properly.
    Problem Solver:
  • 17 Answers
Clean your memory card if you are using a add on video card clean it to using a pencil eraser
clean the memcard and video card seat using a paint brush or an old tooth brush
re seat the video and memory card...
this may solve your problem for now remember that a good cleaning maintenance may take some minor problem that result shoot down in your PC
Try to clean it up by blowing up air using air compressor or vacuum cleaner to remove dust inside you computer..... post here if this solve your problem or not
Posted on Oct 22, 2011
  • 90 Answers
Hi buddy!
maybe the sucket of fan for processor have a problem try to change slot ok this is possible you find that slot is working fine ok.thnx
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Sep 22, 2008
Way to slow down the z5610 acer fan? it runs loud after 2 years.
http://computershopper.com/desktops/reviews/acer-aspire-z5610
A) Needs to be opened up. Needs to be cleaned out inside.
Two years? Bet it looks 'scary dirty' inside. After you have cleaned out the inside, donate the 'Gunk' to local mice. They can use it for a condo. (I would charge them rent)
B) Processor may need old Thermal Paste replaced. Clean top of Processor, and bottom of finned Heatsink, and PROPERLY apply fresh, new Thermal Paste.
Primer:
Air is used to cool the inside of that All-In-One desktop computer. The Processor and graphics chipset, are the two hardware components that give off the most heat.
The finned Heatsink, and Processor Fan, are the two cooling components for the Processor. When they get clogged with 'Gunk' over the years, the cooling capacity drops -> tremendously.
The Processor fan sensor, senses that the Processor is too hot, and speeds the Processor fan up. Also BIOS speeds the computer case fan/s up.
Could also be that the bearings for the fan/s are bad. Replacement fan, or fans are needed.
Acer Aspire Z5610 All-In-One disassembly,
http://www.youtube.com/watch?v=f7vpJTdmMAg
ONE THING HOWEVER Karl, to work on this All-In-One you need to wear an ESD wrist strap, and have it's alligator clip connected to a good ground source.
This is just like working on a LAPTOP computer, NOT a desktop.
Average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
(And of course unplugged from power)
Need guidance in cleaning, and replacing the Thermal Paste, just post back in a Comment. I will guide you.
Regards,
joecoolvette
Oct 08, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
Processor gets hot, cooler and motherboard do not care
You will need to cool it down make sure all the fans are working properly and clean the dust out this is important if you do not do this the processor will burn up and you will damage your computer. This is a critical fix my friend thanks for using FixYa for all your questions. John
Feb 09, 2011 | Acer Veriton 3600GT PC Desktop
Why my computer shut down every 2 hours
right click on the desktop click on properties select the screen saver option in this option u can see the power option and selcet never option of turn off hard disk and standby options.
Nov 15, 2010 | Computers & Internet
MY PC ACER ASPIRE T310 ONCE I SWITCH ON IT DISPLAY NO SIGNAL, I CHEK IT ON PROCESSOR,RAM,VGA N MOTHERBOARD ARE OK. What cud b the problem? I need a solution.
Hi Good day!!! check the both ends of your VGA cable maybe it is not connected properly or it loosen up. Hope in works now!! if not just reply to me and i will assist you more...
Regards
JR
Oct 16, 2010 | Acer Aspire T310 PC Desktop
The computer shuts down after 10 to 30 min..I have already change the fan.
When computers shut down like this they are getting the signal from the motherboard. This is most likely a thermal shutdown signal from the processor. When you changed the fan, did you clean the processor off and apply a small thin layer of thermal paste? The processor may not be cooling properly or the motherboard is getting a bad signal from the processor's thermal circuit. Try new thermal paste on the processor and then go through the board again and make sure everything is in its place. Also, leave the side panel off and see if the system stays running, this will aid in the cooling. Let us know if it works, if not we may have more ideas to help.
Aug 25, 2010 | Computers & Internet
Booting problem
DEAR,
AS PER YOUR PROBLEM I THINK YOUR COMPUTER WORKING WITHOUT ELECTRIC EARTHING. PL FIRST COMPLETE EARTHING WITH ELECTRICIAN.
YOUR EARTHING IS NOT PROPERLY PL CHECK THAT:-- ELECTRIC SHOK ON PC BODY.
YOUR PROBLEM WITH POWER SUPPLY OR PROCESSOR,MOTHERBOARD.
PL FIRST CHECK POWER SUPPLY,SECOND CHECK YOUR PROCESSOR WITH ANOTHER PC MOTHERBOARD.
Feb 25, 2009 | Acer Aspire™ T180 PC Desktop
No Power
please change your SMPS (Switch Mode Power Supply) it's not working properly
Oct 29, 2008 | Acer Aspire™ T180 PC Desktop
My acer just shutdown after 5-10 seconds of being on, I first brought my acer to a computer repair shop, the tenant Diagnosed the problem was my fan. So I change the fan and I still have the same problem,...
Most properly the laptop shutdown itself it due to processor overheat problem. Bring back the laptop to the shop you changef the fan and ask them to check whether the heatsink with fan is tight properly to the processor.
Jul 24, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
