Question about Philips 60P8341 60" Rear Projection Television
Question about Philips 60P8341 projection tv
Hey, I saw you had replied to a guy that said he had his tv power off, and blink 3 times...
I'd like to ask you what the problem with my tv is. Its the philips 60P8341, and I purchased it from a friend. I hit the power button, and I get no picture, but the power button flashes twice, stops, then twice again, and so on. Is it an easy fix?
Thank you in advance.
  • Philips Master
  • 8,617 Answers
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Posted on Sep 23, 2008
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
Will not power on.
its either the fuse or the main filter panel ( power Board) You can get replacement boards at the following link with free tech support to help install if needed.
Apr 02, 2009 | Philips 60P8341 60" Rear Projection...
Philips projection tv
replace voltage regulator and serounding capasitors, check the hv swiching transistor and serounding diods.
thanks,
daniel.
Jan 13, 2009 | Philips 60P8341 60" Rear Projection...
Service manuel
Does the led blink when it shuts down? and will it stert up again when you press power? Let me know and I can assist you with the most likely cause.
Aug 26, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Tv fix
that is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
Jul 14, 2008 | Philips 60P8341 60" Rear Projection...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
Phillips tv 60p8341
You should probaly get the service manual. you can get one at the following link for 15.99 and they provide free support to help you diagnose the set. they email them out fast after placing a order. Have used them many times.
May 29, 2007 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
