Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker I just bought a whirlpool gold fridge and conected the ice maker and it started leaking from the front bottom there is a knob there you can go up or down with but the water still flows out
  • 943 Answers
Hi. Thanks for the question. the problem is . the brass fitting is missing . Or not connected .If missing . The hardware store will have this fitting . Thanks .The Appliance Doc
Posted on Sep 30, 2008
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
I have a 3 door Whirlpool Gold fridge. The bottom
ACTUALL FREEZER TEMPATURE MAY BE ABOVE 17 DEGREES. THEN THE ICE MAKER WILL NOT WORK. OR MOISTURE GOT IN TO THE HEAD OF THE ICE MAKER AND FROZE THE GEAR.
Apr 24, 2010 | Refrigerators
Ice maker is frooze up and has quit making ice water has gathered in the bottom of the fridge
this may be a defrost problem being that water in bottom of freezer is coming from frem defrost and drain is blocked
is the freezer down to -18 deg c ?
the other problem is that the water inlet valve is leaking water into chamber when is not meant to
so if water valve is faulty this can happen so replace valve
Nov 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My icemaker makes large hunk of ice
IF YOU REMOVE THE FRONT COVER OF THE ICE MAKER THERE ID A SCREW TO ADJUST THE SIZE OF THE ICE CUBES TURN IT DOWN AND YOU WILL GET SMALLER ICE CUBES ALSO SOME MODELS HAVE A OUTSIDE KNOB TO ADJUST SIZE,LET ME KNOW-MIKE
Jun 17, 2008 | Whirlpool Gold Series GI15NDXT 15"...
Whirlpool gold
Your drain was clogged. look for the drain funnel then remove the dirt.
Jun 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
