Question about Zephyr Milano-S ZMI-M90S Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
After the power went out this morning our Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
  • ronio Sep 28, 2008
    Hey Harvey,
    Thanks for the information. I now know more than I did before about this unit. Meanwhile, I called Zephyr in San Francisco and they called me back! The solution was to turn the breaker off and wait a few minutes (25-30 was recommended but it didn't take that long) and turn it back on. This worked. The technicial expert at Zephyr explained that this is a saftely feature of the device and this is how it responds to power off situations sometimes.
    Thanks for the response
    Ciao,
    ...Ron
  • Anonymous Mar 13, 2014
    light switch zephyr hood
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
Zephyr typhoon ak2136 stopped working
I have the same problem with my unit. Have contacted Zephyr support and hope they have answers.
Jan 04, 2012 | Zephyr Typhoon AK2136 Kitchen Hood
Terrible noise when fan comes on...
The fan is most likely hitting or scraping into something. Disconnect the power and open up the fan panel. Push the fan blade manually and see if it's hitting into any walls. If not it may be the vibrations from the motor. In this case you should tighten any bolts that aren't completely tightened
Mar 13, 2010 | Zephyr Milano ZMLM90 Stainless Steel...
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Can't figure out how to get bulbs out of hood to replace on Zephyr Milano-G ZMI-M90G Kitchen Hood
just use an adjustable pliers wide enough to grip the outer small edges. Grip, turn counter clock wise and remove. The other way to do this is unscrew the panel behind the filters and you should be able to reach the neck of the bulbs.
Nov 30, 2008 | Zephyr Milano-G ZMI-M90G Kitchen Hood
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Milano-S ZMI-M90S Kitchen Hood Logo
1,121 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
Tom Chichester
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
