Question about Denon AVR-1604 Receiver
No sound The display on the front of the receiver is still illuminated; however it does not produce any sound...Does anyone know how to get to the amp fuse and if it is the fuse, where do I find a replacement.  Also, is replacing the fuse just like replacing a fuse in car audio, or is it different. Any suggestions would be greatly appreciated.... thank you Joe
  • 3 Answers
Yup, try opening the case and locating any fuses you can find. IMPORTANT! Make sure unit is unplugged from power source.
Fuses are somewhat like light bulbs in that they can an do burn out. Use ohm meter to test if fuse is good.
The fuses are usually just like automotive fuses so you can try to find an amperage printed or stamped on the fuse. Replace with same.
GL!
Posted on Oct 04, 2008
No sound produced by Yamaha RX-A820 receiver.
sounds like amp has burned out, disassemble and check for blown fuses.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jan 30, 2016 | Yamaha Audio Players & Recorders
Only one of the front speakers is producing sound.How can i set to receive sound from all the speakers?
hi,
first check all the connections to the speakers. then go for the following
Press SOUND FIELD on remote repeatedly until the sound
field you want appears in the front panel display.
ok
Dec 18, 2010 | Sony DAVHDX265 System
Should all the surround sound speakers be working when I am watching satelite TV? Mine do not, just the front left & front right have sound.
All speakers should be working. The display on the Sony unit will tell you which speakers are enabled with a box illuminated and each speaker that is decoding with the speakers abrevation eg SL for surround left also illuminated. If these are not displaying then you need to check your playback mode. If play back is set to 2CH you will only get the front speakers. Try setting play back to AFD ProLogicII, Movie, or Music. If this does not get the speakers running then check the speaker configuration in the setup menu. It should be set to 5.1, if not set it and press enter to save it. If this is setup correctly then try the level settings in your menu. Each speaker has a setting that can be adjusted up or down to effect the loudness of the speakers. If this does not do it then check the connectons at each end of the suround speakers ie, at the receiver and at the speaker.
Dec 02, 2010 | Sony STR-DE897 Receiver
No sound out of front left speaker
front left channel power amp needs rpair
Jul 08, 2009 | Sony STR-DG510 Receiver
Front Display Panel Letters are Scrambled and Cannot Be Read
Could need to be reset. Try unplugging it for a couple of Min's. it may reset itself. If not send me a message and I'll check the service manual for the reset procedure on Monday when I go to that hell they call work.
Mar 06, 2009 | Yamaha RX-V800 Receiver
Kenwood kcd-v6017 no sound
My kenwood X792 has an option to turn the internal amp on or off, having it off (despite having an external amp) produced no audio, since it ONLY produced audio out of the line-outs with the internal amp off.
May 10, 2008 | Car Audio & Video
No sound at all coming out of the AVR745
The audio amplifiers circuits are damaged send it to a repair shop.
Apr 03, 2008 | Harman Multimedia AVR 745 Receiver
TX-DS494 Surround Sound Issue
don't switch to stereo mode. switch to prologic mode
Aug 06, 2007 | Onkyo TX-DS494 Receiver
No sound from the reciever
Plug in your headphone, if you hear music then it could be the speaker's fuse blown up, or the speaker's circuit breaker shut down. If nothing sound then possibly the strong static has burned down the audio/receiver's circuitry section.
Jun 08, 2007 | Yamaha YHT-440 System
Amp powers on, but no sound is produced
a failed volume control potentiometer? it's possible.
Jun 04, 2007 | Sherwood RD-6108 Receiver
Denon AVR-1604 Receiver Logo
798 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
