Misfed paper jam in section A. Cleared machine and still telling us there is a jam. For a Savin copy machine model 2535 My e-mail address is: kathleen.m.boyd@exxonmobil.com phone number is 815-521-7402
  • 97 Answers
- Double check if they have paper inside the machine
- check the tray and other open doors.
- clean all sensor area.
Posted on Sep 22, 2008
How do I fix paper jams for Savin 4018d
If it jams on the way out every copy the the exit switch is out of position or broken, if not then sep pad p/n B0392711. -Carl
Jan 21, 2015 | Savin Office Equipment & Supplies
Double Sided Copies on Savin 2535
The image shows a flat page with a 1, arrows to an image of a sheet with the lower right corner turned up with a 2 on it. On a Ricoh, just remember that the first image is the input and the second is the output.
Feb 06, 2014 | Savin Office Equipment & Supplies
I REMOVE THE JAMMED COPY. PRINTER STARTS AGAIN AND JAMS UP AGAIN ON THE VERY NEXT COPY. COPY SEEMS TO BE MADE BUT CAN'T GET OUT OF THE EXIT
Jam may not be completely cleared or paper is not suitable for your printer.
You can find your User Guide, an Educational Guide on the paper which is compatible with your printer and updated Drivers here:
http://my.okidata.com/PP-B4350.nsf?opendatabase
In the Troubleshooting section of the User Guide (page 74 of the English version) there is a section on dealing with Paper Jams. Make sure you have cleared all areas and that your paper is compatible.
Trust this is helpful. Please vote.
Dec 25, 2010 | OKI B4350 Laser Printer
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
I have a Savin 2015 DP and it says that there is a paper jam. there is not, i have already cleared it and the light wont go off, therefore, my machine is out of service. any advice?
There is a sensor lever that gets stuck on these models. The sensor is located just below the drum . (might be on its own door cant remember) it should move freely if it is stuck in the jam position the jam wont clear.
If you still nee help reply and I will try and assist futher.
Good Luck
Apr 09, 2010 | Savin 9935DP Laser Printer
Misfed paper
Clean the paper feed roller and select the copy mode paper tray correctly.
Sep 28, 2009 | Office Equipment & Supplies
Had a paper jam. Cleared it. ''Clear misfeed'' light still on.
have you tried turning of the power and unplugging ALL cables including telephone line . leave for 1 min then recconnect and try again. Or could be a very small piece of paper as a little near the sensor will confusew the machine
Jul 30, 2009 | Office Equipment & Supplies
Showing misfed paper @ U1 U2, paper jam out, but still showing misfed.Checked and all paper is out. How can this be reset? Thanks
in the machine can be a little fragment from a sheet of paper so watch careful it can be right on the sensor for registration please open all doors and close them again.
But for i to be able to help you more you will need to tell me what brand is the machine and which is the model
Jul 15, 2009 | Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
177 people viewed this question
jasbo
jasbo
