This problem should be removed because:
Problem with Whirlpool MH1150XMQ 1000 Watts Microwave Oven
I have a MH6150XMQ Whirlpool Micro and the light comes on with the fan but it does not heat nor does the turntable rotate. The turntable is turned on via the front push button. How can I troubleshoot
this problem to identify the defect. This happened after a thunderstorm.
Solutions (1)
Best Solution
While the turntable can be prevented from running while cooking if you turn it off with the keypad, that's probably not relevant here.
This
problem is usually caused by either a bad upper door switch or a loose door switch
mount, which are pretty simple problems to fix.
My help file on door switches is here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Testimonial: "William nailed it. The upper door switch would not work when the door was closed. Open it the smallest bit and it worked. The connectors were colored blue from excessive heat. The middle switch worked but had blue connectors too. I have ordered replacements for all 3. Thanks William"
27 day old MH1160XSQ micro-wave-
27 day old MH1160XSQ micro-wave- turn table will not turn.
Heating went out
I have a MH6150XMQ Whirlpool Micro and all of a sudden the heating went out..what can I do to find the problem?
Describe your Whirlpool JKP90B0M1BB Micro/Wall...
Describe your Whirlpool JKP90B0M1BB Problem The rotating thing won't rotate. It just stopped going around in circles and I don't see...
Frigidaire FMT 148GP Microwave oven. Turntable
Frigidaire FMT 148GP Microwave oven. Turntable does not rotate although Turntable On button is activated
my panasonic micro-oven is working but the fan
my panasonic micro-oven is working but the fan and turntable are not operating.
Add Your Solution
how to instaal door handle om whirpool model...
how to install door handle
whirlpool MH1150XMQ0 over stove light not working
The light for the stove does not work that is under the unit, I can hear the relay clicking when I press the switch but...
my night light dont work,have put new bulb in...
is there a fuse that has blowed
My Whirlpool MH8150XMB microwave stops heating...
Light, control panel, exhaust fan, turntable will continue to work, but all sound stops and food stops heating.
See all Whirlpool MH1150XMQ 1000 Watts Microwave Oven Problems
Fix-O-Meter
369
369 people viewed this problem
- 1 person found this problem to be helpful.
- 2 people are following this problem
Top Whirlpool Microwave Oven Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
> Will the fan and light still come on if a door switch is bad or loose?
Yes. The top door switch on this model supplies power to both the turntable and the high voltage section of the oven.
If the switch is not being activated, the symptom will be that everything works except that it will not cook and the turntable will not come on.
Also, the stirrer motor will not come on, but you'll not notice that unless you run the oven without the stirrer cover in place.
See marked tech sheet excerpt here:
http://031d26d.namesecurehost.com/mwd/mh...
