Question about Black & Decker Camping, Backpacking & Hiking
How to get parts
Need a replacement power adapter. Used gift so no papers and no adapter.
    Champion:
  • 242 Answers
Buy a universal power transformer that has a switch for changing the voltages and has different sized tips that would fit in your flashlight.
Posted on Oct 23, 2008
Netbook no power
there are three possible reasons of this issue.
1. Ac adapter
2. Battery
3. Motherboard - you don't want this part to have a problem. It is very expensive.
For this, you need to isolate which part is causing the problem.
1. Remove the battery from your netbook and use the ac adapter only in powering up your computer.
2. If it's not turning on (battery out and only the ac adapter is used), then check your ac adapter for signs of defects. It could be the ac adapter or the motherboard. If you have another ac adapter then you can try it.
3. If the ac adapter works with the computer, then you would need to replace the battery.
Let me know if you have any questions.
David
Jul 13, 2013 | eMachines Computers & Internet
Notebook woks on battery but does not on power supply
Hello. It sounds like either...
1. Your Asus power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 10, 2012 | ASUS (F50SV-A1) PC Notebook
Toshiba satellite won't go on
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Power tip?
If you need to run this at any time for a recharge then you will need the AC power pack and the Car power tip. Go to any garmin site and purchase or even try on Ebay as this is the cheaper option most times.
Please rate my help++++Thanks for using Fixya
Feb 07, 2010 | Garmin nuvi 200W GPS Receiver
I have problem with my charging system.
hi ravijdv2813,
your problem is your battery doesnot workon another laptop,i think the battery does't catch up with the laptop,if you have time you suggest you buy one from online shop of http://www.adapterlist.com. which conents some Battery Part No and Battery Fit Model.hope this infoemation can help you solve your problem.
Jul 15, 2009 | BafoTech BAFO BF-810 Serial Adapter
Can a Panafax UF-550 somehow be used on a pc as a printer?
Yes, you will need a Centonics Printer cable and the drivers for your operating system
If you do not have a printer Port on you computer you will need the above cable and a USB to Centonics adapter.
Feb 09, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Hi, I have an HP Deskjet 450wbt Printer (where the wbt is in the model number and stands for wireless bluetooth). It's a few years old and now I need a replacement Power Supply. When searching (using...
Here are some part numbers for you. I found both these items on ebay but you might be able to find them other places. I just used ebay to check if the part numbers were correct. There are two cords that you need to power the machine.
1) The Power Cord: PN# 8120-8900. This cord plugs into the power module then into the wall.
2)The Power Module: PN# 0957-2229. This cord plugs into your printer and has a place for the power cord to plug in.
There might be some places that sell them both together but be careful if you have lost both these you will need them both to power your machine.
Hope this helps
Dec 05, 2008 | Office Equipment & Supplies
Trutech 7" Digital Picture Frame
hi!!!!
if your power supply have warranty? then you can replaced it!!!
Sep 18, 2008 | Computers & Internet
Camping, Backpacking & Hiking Logo
85 people viewed this question
Top Black & Decker Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black & Decker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
