Question about Bissell 1400 Little Green Pro Canister Steam Vacuum
Dirt/Collection Tank Bissell Little Green
Are you supposed to be able to take apart the dirt collection tank to clean the parts inside? I only seem to be able to remove that small black stopper. I have run water through the tank under kitchen sink tap but there is still all sorts of dirt that is not leaving the tank.
  • neener179 Oct 28, 2008
    I have the same problem. Im thinking of buying a different cleaner... one that can be taken apart. The little green cleans but all the dirt is left there and it cant be taken out
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Posted on Jan 11, 2009
  • Shelby Munnoch
    Shelby Munnoch Feb 13, 2015
    THANK YOU! I have tried to figure out how to clean this for over a year. I didn't have rocks, so I used rice. It worked pretty good and I could dump it down my garbage disposal.
  • 37 Answers
No it doesn't come apart. you may want to soak after each use with hot tap water. sorry:(
Posted on Sep 25, 2008
LIttle Green Bissell Water goes directly to collection tank, won't spray
Had a problem with mine not spraying, took ot apart and the heater for the solution was plugged with scaling, cleaned it up and works the very best now. As far as clean water going directly into the collection tank, sounds like the little hose may have a break or a leak in the vacuum hose.
Mar 14, 2018 | Bissell Vacuums
Where to fix float in collection tank
Hey Val, inserting the float is quite easy. Turn the tank so the flat side of the tank is facing you. Where it says, "Fill with Clean Water to here", there is a groove on the inside of the tank just behind the writing. Slide the rattle sounding weighted end of the float vertically into the groove. The float will only fit in one way.
Jan 31, 2013 | Bissell 7700 Big Green Complete Vacuum,...
How can I clean or open the bissell quicksteamer dirty tank
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Jan 16, 2013 | Bissell 1770 Quicksteamer II Upright...
I SEEM TO BE CONFUSED AS TO WHAT SIDE THE WATER GOES. ALSO WHAT SOLUTION OF CLEANER SHOULD I USE. MY PRODUCT IS THE BISSELL LITTLE GREEN.
Water goes on the left side and the collection tank is on the right. I suggest the Bissell soultion it runs about $10
May 07, 2011 | Bissell Vacuums
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Aug 04, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Can't clean little green collection tank
You could try a solution of hot water and baking soda. Works very well for coffee residue on a carafe. Dilute and filter the soda before pouring solution into the tank . then hold the tank and swirl.
Sep 06, 2009 | Bissell 1400 Little Green Pro Canister...
Emptying the powerbrush
Gently
press the Quick Release tabs on the Clean/Solution Tank
and slide the tank off of the unit.
Grab the Dirty/Collection Tank and pull to remove.
While at the sink, remove the Tank Cap by turning
approximately 1/4 turn counterclockwise and lift
out the cap.
Empty the tank. Rinse the Dirty/Collection tank with
warm water.
Replace cap and turn approximately 1/4 turn clockwise,
until snug.
Slide the Dirty/Collection Tank into the unit. Replace the
Clean/Solution Tank.
The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Bissell 1400 Little Green Pro Canister Steam Vacuum Logo
4,922 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
