Question about Samsung CLX-3160 All-In-One Laser Printer
Printing is hard to see - Not dark enough
I put in a new waste toner kit but the printing is too light. I can barely read the print. Does the machine clean itself. What must I do to get sharper printing.?
  • Roberta Smith
    Roberta Smith May 11, 2010
    not sure about cleaning but remove the toner cartridge and shake it abit... put it back in and try it out
    Robert
jaylex
  • 417 Answers
SOURCE: printer not printing
On the machine there is a sensor that looks trough the waste tank even though you have wiped it clean the likely thing is that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
Hope this helps you
Thanks J
Posted on Jan 07, 2008
rtrahan
  • 741 Answers
SOURCE: my hp 1200 printer is not printing dark enough.
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Posted on Apr 20, 2009
  • 1550 Answers
SOURCE: printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
Posted on May 27, 2009
  • 1040 Answers
SOURCE: My printing colour is not dark enough to be
Hi..
Not just the print cartridge but make sure that the "Print Head" is also working fine. ink clogging has not taken place on print head.... Print head is a hardware, on which cartridge is attached.
Hope this has helped you.. Thanks..
Posted on Sep 29, 2010
djgillstudio
  • 107 Answers
SOURCE: Receipt is not printing dark
hello, have you cleaned the thermal head with isopropyl alcohol, and a soft cloth, according to user manual, this should be done, being gentle with it.
Posted on Sep 30, 2010
Printer with new toner cartridge printing too light to see almost
Recover the cartridges, en sure there is no 'transportation tape still on the cartridges, if not gently share the cartridges horizontaly whilst also holding it horizontaly. Try again. If it still points incorrectly send it back for a replacement,.
Nov 10, 2014 | HP Laserjet 3030 All-in-one Laser Printer...
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Dark printing on the pages with the text
you will probably need a maintenance kit. After a while the toner roller and fuzer rollers wear down and allow more toner to be put on to the paper than is needed.
Dec 06, 2013 | HP LaserJet 5100 Printer
Lexmark T642 print gray though new cartridge
The main cause of light print is a bad set of charge and transfer rollers. These rollers are used to put a charge on the paper and transfer the toner to the charged paper. When the rollers get worn out they can not put the proper electrical charge on the paper so the toner does not stick to it as it should. One roller sits under the toner cartridge and on is on top on the cartridge. If you pull out the toner and look inside the printer you will see the transfer roller and if you start to close the lid with the toner out you will see the charge roller come into view. Here are pictures of each one. Transfer roller first.
These rollers come in the preventative maintenance roller kit. This kit is available at the following link. The kit also comes with the pickup rollers.
http://www.ccl-la.com/catalog/product_info.php?products_id=301
Jan 25, 2013 | Lexmark T642 Laser Printer
Samsung CLX-3160 I put in a new black toner because the older one
This is the problem in the Black developer in the Imaging unit. Please call samsung or visit authorised service center
Nov 09, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer not printing dark enough
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
Apr 20, 2009 | HP LaserJet 1200 Printer
Very light printing
One thing you can do, and this part directly affects print darkness if bad, is to replace the Transfer Roller. It is a roller with a steel shaft, located beneath the toner cartridge, and it is part of the printer itself. easily removes if you pull up from one side it will come free of the plastic saddle clip, and the other end of the shaft is in a round hole slot. replacing this part with a new one will probably restore print darkness.
http://www.fusers.com/shop.cfm?page=list.cfm&action=list&criteria=64&cat=58&makeid=14&modelid=15005&var1=10&var2=&var3=&man=&afid=204&stay=
ken
Nov 15, 2008 | Office Equipment & Supplies
Samsung CLX-3160 All-In-One Laser Printer Logo
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
