Maytag washer leaking oil on the floor!
My washer is leaking oil out of the bottom of the trans! Is this easy to fix? Maytag Atlantis MAV6257AWW
  • 641 Answers
SOURCE: Maytag Atlantis MAV6257AWW
Well done !
Posted on Jul 30, 2007
  • 4 Answers
SOURCE: Mayatag Atlantis Top Loader Washer Model MAV6451AWW
there are two clips about 3 inches in from the corners in the front between the top and front panel.you push a putty knife into the space between the top and front panel about 3in in from corners and lift the front of the top.
Posted on May 12, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
SOURCE: washing machine leaking oil
your washer has a transmission and this is what is probably leaking. You might simply need a new seal or the a new transmission. You need a good handyman or contact a repairman.
Posted on Dec 02, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag top loader leaks at the bottom of the bucket. I took off the front cover and should see that the wahser at the top of the shaft is leaking. Is this an easy fix?
not easy, unit must be stripped to allow access to bottom seals and bearing/s. Special tools needed and a goog knowlege of the wiring.
Sep 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Leaking Maytag Atlantis @6 yrs. old
Do your work from the back of the machine.
Jul 07, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My top load maytag leaks from the bottom during wash cycle
90% chance it's just a loose hose or a bad fitting/clamp. Very cheap and easy to fix. If you like your washer, I'd say either pay to have someone come repair it, or if you are handy (or have a handy friend) give it a try yourself. You'll have to remove the back and find the leak.
Jun 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Tub leaks water during cycle out bottom onto floor
We had the same problem. There was a pinhole leak in the hose that connects the tub to the pump. Bought a new hose for under $10 and fixed the problem ourselves.
Feb 26, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlantis washing machine
It will not spin out all of the water out of clothes, spins VERY slow
Dec 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
