Question about Garden
Tractor?troy bilt/mtd 2002
The PTO to the blades will not engage. The belts are good. The spindles turn when hand turned.
  • 2 more comments
  • Chad Houston
    Chad Houston May 11, 2010
    Will the blades turn by hand?
  • Anonymous Mar 15, 2014
    I can not get the pulley off. The tractor is a GT235.
  • Anonymous Mar 17, 2014
    pto engages as soon as ignition is turned to run blades turn when starter engages
  • Anonymous Mar 30, 2014
    46" deck
The blades turn by hand. I had been cutting the grass. Stopped, turned it off, went back later to finish cutting the grass. Started the tractor, drove to the area I was cutting and pushed the PTO to engage blades but nothing happened.
Posted on May 06, 2013
  • 163 Answers
The electric clutch that operates the blades needs replaced
Posted on Nov 30, 2008
I have a troy Bilt riding mower and When we turn pto on to engage it will engage but the noise is so loud. And the pto will not stay in the on position.
check and look at deck [ unit not running and key in pocket ] for loose ,damaged ,debris or out of alignment==belt ,pulley , mandrel,tention/actuator pulley or blades
May 04, 2017 | Troy Garden
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @
May 30, 2011 | Troy Garden
Mower deck shakes when PTO is engaged
An imbalance is causing your vibration. check the blades. You probably have a bent or damage blade. Could also be a bad spot on the deck belt or a damaged spindle.
Good luck.
Sep 06, 2010 | Mtd Garden
Whenever I engage my PTO may engine bogs down, what may be causing the problem?
do you mean when you engage the cutters? if so then chances are on of the blade spindles may be seized or stuck, disconnect the belt from engine pulley and try turn the blade spindle pulleys by hand one at a time to see if they are spinning freely
Jun 13, 2010 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
    Ranch King is a brand name of the manufacturer MTD.
    Product manuals with part blow-up diagrams are available from MTD's web site,
    Models are identified from the model number printed on a label under the mower seat.
    The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
    Parts can be ordered directly from MTD or other distributors on the web.
    It is my experience that original brand name MTD belts work best.
    The 22HP, 46" mower deck Ranch King Pro has 3 belts:
    The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
    A mower has either an electric PTO or a manual PTO, not both.
    The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
    The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
    The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
    In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
    Sep 07, 2009 | Mtd Garden
    Garden Logo
    496 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
