Question about HP LaserJet P2015dn Printer
P2015N - Printing Information pages after every job
I have a HP P2015N in another Department that keeps printer a HP Information type ad'safter every job.
Any ideas on how to stop it
  • 87 Answers
I hope that the printer is able to print internal test pages without any issue. However, if thats true then I can say that the printer as a standalone machine is working fine. Hopefully, the printer is connected over the network.
Hence, I request you to reinstall the driver from the following link.
Posted on Nov 03, 2008
I have P2015n laser jet network printer. Since last two days garbage printing is contineously going on how to reset or stop this printing. Pl. give solution. Nitin Joshi
1, Go to your services and restart Print spooler (start-run-services.msc) start stop it 2. Reinstall printer driver 3. Check your network or USB cable (depends how you have conected it)
Best regards
Mar 01, 2011 | HP LaserJet P2015n Printer
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
My printer hp laserjet 2015n get hangs frequently, at the same point of time i have to restart the printer and then it starts working..
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | HP LaserJet P2015n Printer
Duplex printing availeble in HP laserjet 2015n?
HP 2015n is not able to print duplex (both sides). HP printers, which have duplex print have "d" after the product name/number - like HP2015dn, 2055dn.
Aug 20, 2010 | HP LaserJet P2015n Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
Mar 20, 2009 | HP LaserJet 4100 Printer
Printer not printing
Remove the toner and check if it is empty also clean the contact point of the toner circuit
Feb 23, 2009 | HP LaserJet P2015n Printer
Laser printer keeps printing hp ads
Please perform the following:
If the printer is connected via network, unplug the network cable and perform cold reset.
Cold reset A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings. Use the following procedure to perform a cold reset.
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
    If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Then uninstall / delete the previous drivers and install the drivers from the following link:
Sep 11, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
63 people viewed this question
Ben Johnson
