Check all of the connections. The frame of the bike is the negative. I would think there is a short somewhere, either inside one of the lamp housings or the wiring harness has chafed and is touching the frame. You will have to check each wire. Check also inside the fuse housing. There may be a wire off or shorting in there.
SOURCE: Brake light
Solution, (after checking all wiring) was bad contacts in rear light. Cleaned them up, and everything works fine now. Always the simplest solution and always the last one you check!!!
SOURCE: 2005 fatboy 15th anniversary front blinkers stopped working
i have to reserch on it and get back with you, talk to you soon.
SOURCE: Speedometer dropping to zero and security light is solid red
sounds like a faulty ground a schematic for your bike should show which ground they share
