Question about SanDisk Sansa e250 MP3 Player
I deleted my file on my portable player sandisk e250 and it fashing on and off.what do i do
  • thangistc61 Sep 23, 2008
    I formated my sansa e250. so, I can't connect it . What can I do?
  • VicThunder Sep 24, 2008
    my saadisk 250 is stuck in refresh data and keeps restarting
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Sep 25, 2008
  • Jean Sintulaire Sep 26, 2008
    Could you provide more details about the problem you are having?
I do not have any software on my computer anymore for my sandisk mp3 player. how can i redownload the necessary program (s) to be able to remove and download music to my device?
You do not need software to use the Sansa e250. You can simply plug it into your computer, and use it as a portable drive. You can drag your music files directly onto the player from your computers file explorer.
Hope this helps!
Mar 18, 2011 | SanDisk Sansa e250 MP3 Player
How do i remove videos off my sansa e250 mp3 player
Connect the e250 to your computer using the supplied cable. Then delete the file using the SanDisk Connect software.
This should be exactly analogous to the method you got the video on there in the first place.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
Cannot delete files from my mp3 player
open up my computer and go to the drive for your device (like mine is E: for my sansa E250, but yours may vary). just browse around the folders until you find where your music is stored and delete it from there.
Apr 25, 2009 | SanDisk Sansa e250 MP3 Player
Deleting Files
Set the player USB mode to MTP then connect to PC, go to the player from My Computer then select the files to delete. After deleting files disconect player from computer to restart and reload files, Once player has reloaded it can be reconnected to computer to sync new files.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 04, 2009 | SanDisk Sansa e250 MP3 Player
Can not see the files/songs i have on sansa e250
It may have an infected file on it. try to put some more files on it
Jan 21, 2009 | SanDisk Sansa e250 MP3 Player
Deleting unresponsive files
try to get your computer to give it a drive letter go to my computer find the device right click then format. ti shoud format
at the same format by defult.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Cannot delete photos Sansa e250
if you have a newer brand computer like and HP for example, go to the control panel, then double click on the Portable Media Devices folder and look for another folder showing what images you have on the device and you can delete them from device
Feb 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
