Question about Uniden Cordless Phone
Where is the page button on the base unit to register phone????????
Please help!! i'm trying to register my handset but cannot find the page button on the base unit. this is model 28106 (just the handset itself) which is for use w/ 28115 and 28118 series.
    Brigadier General:
  • 5,158 Answers
If i'm not mistaken all you do to register the phone is put the handset into the base unit ... i believe the light flashes for a sec then it's registered... repeat that with all the handsets you have. it will not be registered if you have put the handset into the spare charging stand if that is included with your phone.
Robert
Posted on Sep 22, 2008
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
How to re register base unit with handset i accidentally de-registered bse unit form the handset by going to base setting in handset option and okaying it. please help me.
Welcome to Fixya
Dear USer
Place your Extension Phone Near to Main for Few times Until it Beeps.OR it Ask for Registration like Please Register or Something like that.Follow the Steps carefully to Register it...Then Check it for Dial tone to Confirm.Some phones may display that the handset needs to be registered. If this appears-Move the handset near to base/main unit & press the "Prog/Mute". Next, press the "Pager" button on the base unit .Then press the "Prog/Mute" button on the handset again to complete the registration.
Hope you got it....Thanks for Connecting FixYa
Sep 03, 2010 | Uniden Cordless Phone
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
I have a model KX-TG9332T.... I cannot get the handsets to link with the base...I have unplugged, moved the system, changed the batteries and both handsets continue to get the message cannot link to the...
Registering a unit Operating additional
handsets
Additional handsets
Up to 6 handsets can be registered to
the base unit.
Important:
L See page 6 for information on the
available model.
Registering a handset to a
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, register the handset.
Handset:
{MENU} i {#}{1}{3}{0}
Base unit:
Press and hold {LOCATOR} for 4
seconds until the registration tone
sounds.
L If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
L The next step should be
completed within 90 seconds.
Handset:
Press {OK}, then wait until a long
beep sounds.
{OFF}
Note:
L While registering, "Base
registering" is displayed on all
registered handsets.
L When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
Jan 18, 2018 | Panasonic Lands Phones
Base unit not recognizing any handset
I recommend that you unplug the other unit and then register each phone separetly. While trying to register one phone make sure the other is un plugged.
May 29, 2009 | Panasonic KX-TG2740 Cordless Phone
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Siemens Gigaset 4200
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Sep 20, 2007 | Siemens Gigaset 4000 Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
New Expansion Handset refuses to register with the base
If im not misytaking the base has to be set up for another expansion too.
Apr 06, 2006 | Motorola Mobility MD7091 Cordless Phone
Uniden Cordless Phone Logo
169 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
