Pye portable flat screen television with a built in dvd. The dvd is not reading
  • 2 more comments
  • wendy210 Sep 22, 2008
    The advice received is try cleaning the lens but I do not know what the lens is..
    Hi Robert.
    No it doesn't read any disc's not just one in particular.
    Hi, There is no door or drawer of the dvd player. It is just a vertical **** in the side of the player that you insert the disc into.
    Ok I will buy this special cleaning dvd and give it a try. Thanks
    President:
  • 1,952 Answers
Cancel the parental lock function or change the parental lock level the pre set passward.........
Posted on Sep 22, 2008
  • 2,071 Answers
Manually cleaning the lens To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don?t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on. To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you?ve covered it entirely. Then repeat using the dry end. If the cleaning didn?t help, don?t despair just yet. You can see if there?s a problem elsewhere in the unit by using a few simple tricks and tips. First thing you want to see if the unit?s laser is in good working order. This method isn?t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that?s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don?t go overboard with the grease though, as too much can cause all sorts of problems. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. If the disc starts to spin slowly and doesn?t come up to speed, the spindle motor that?s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you?re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak. Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved. hope this may help; Regards, VOTIT
    Brigadier General:
  • 5,158 Answers
The lens is actually inside the dvd player and very sensitive device. it reads the information from the disk.... the problem is if you clean it with the incorrect solution or cause it to go out of alignment it's toast. does this device not read other dvd's or just one in particular ?
Robert
    Genius:
  • 2,035 Answers
Please mention the model number, are you getting error message try to clean the lens and then play the disc ..
  • Anand Kumar
    Anand Kumar Sep 22, 2008
    You will get a lens cleaner disk in any electronic shop its usually a disk which cleans the lens of the dvd player which is used to generate laser which ables to read the dvd's ..
    Genius:
  • 1,847 Answers
Try cleaning the lens with the len cleaner and then try
  • Legin Varghese
    Legin Varghese Sep 22, 2008
    the len cleaner is dvd which you buy from local music shop or online from ebay. this special dvd can help you in cleaning the len.
Magnavox portable dvd
If there is an output on the portable TV/DVD, connect a cable from the output on the portable to the input on the flat screen. If there is nothing labeled output on the portable, this is not possible. Sorry
Apr 09, 2014 | Televison & Video
The in-built dvd has stopped reading dvds - the msg on the screen is 'no disc' and then it ejects.
That usually indicates that the dvd laser might be bad. It also could be the belts. Repairs are usually pretty resonable. Hope this helps.
Jun 02, 2011 | Televison & Video
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
Apr 17, 2010 | TruTech PLV16190 Television
Hi. Hope you can help with a DVD problem we have with our Polaroid TDA-03211C television: After I insert a DVD, I hear two clicks and then the message "No Disk" appears on the screen. The DVD player is not...
We had the same problem. Call Polaroid and they will send you a replacement dvd player. It was a malfunction on their part. It seems the DVD player gets too hot and then it doesn't work anymore.
Nov 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Does not read disk
My portable dvd player turns on and the disk does not spins but the screen turn light blue and does not read the disk
Aug 03, 2008 | Liquid Video MVBG45 Portable DVD Player
PET700 portable dvd player
Suspect the optical pick up, may be cheaper to buy a new unit!
May 29, 2008 | Akai LCT3201TD 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
