No special tool needed (usually). The armature is resting on a tapered part of the shaft. Assuming that you have removed the stator and have exposed the armature and have removed the center bolt. Apply penetrating oil to shaft so that the oil can enter between shaft and armature (wait for oil to work at least half hour). Hold piece of hardwood against metal part of armature (first one side then other) and rap very firmly with heavy hammer. Be careful not to hit metal directly or wiring. If the oil has done its work, the armature will come off with first couple of hits. If not add more oil and wait. Then try again. Good luck.
