Philips 51PP9100D 51 in. Television
Problem for Philips 51PP9100D 51 in. Television
PHILIPS MODEL # 46PP93 0217 40 INCH.
By CARLTOR1966 on Sep 22, 2008
WHEN WATCHING ON CHANNEL ESPN THE INFO THAT GOES BY ON BOTTOM OF TV , IT GOES BY WITH A WAVE !
Solution #1
posted on Feb 09, 2009
Not Rated)
Ecollier2012
Rank: Guru  Philips Expert
Rating: 93%, 558 votes
It may be the fluid in the CRT or the convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Was this helpful?
Yes
No
Popular Solutions for Philips 51PP9100D 51 in.
Questions and Unsolved Problems for Philips 51PP9100D 51 in.
Do you recommend Philips 51PP9100D 51 in. Television?
Answer
Answer
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection.... (More)
Answer
We have a philips 51pp9200/37 tv. It has convergancen issues. we replaced the chips but that didn't... (More)
Answer
The Hitachi 53fdx20b I'm looking at getting really cheap seems to have the extreme misalignment of... (More)
Answer
I have a philips 51pp99100d hd tv. The tv started powering down on its own. Now when I hit the... (More)
Answer
My issue w my tv is that i cannot find the convergence option any where on the settings menu. well... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
