Question about iRobot 5800 Scooba Vacuum
Scooba 5800 It vacumms but it does not release any water. Tank is full. What do i do?
  • 2 more comments
  • cocacolanut2 Nov 01, 2008
    The tank if full, the green light is on, but it will not release water.
  • resqdan89 Dec 27, 2008
    How do you prime the pump..
  • corbani Jan 13, 2009
    How do I prime the pump? What are the rubber thingie to align? In the manual nothing says to prime the pump or other stuff. This is my third scooba not working: the first one was not starting, the second one had the wheels stucked and this one no water is coming out.
  • Anonymous Mar 21, 2014
    Won't vacuum water up
Did you try priming the pump?
Posted on Oct 25, 2008
I had this problem several times. Once I needed to realign how I had inserted the lint screen and the other time I had to realign how I put the rubber thingie in and i was sucessful both times.
Posted on Dec 13, 2008
IRobot Scooba 5800 "check tank" light
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Dec 31, 2013 | iRobot 5800 Scooba Vacuum
My scooba is not releasing water from the clean water tank
Sorry to read about your problem, I hope this helps you out.
if you have not cleaned out the unit very well you may have a clogged line, please look at the link
http://homesupport.irobot.com/app/answers/detail/a_id/654/p/31
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | iRobot 5800 Scooba Vacuum
Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | iRobot 5800 Scooba Vacuum
My Scooba floor cleaner "check tank" light stays on even after it's refilled and everything cleaned but still will not work. It just keeps beeping at me when I try to start it. How do I reset it or get...
Flush out the solution valve with water (aka "prime the pump"). Use water, not just air, because water will clear any obstructions that may be in the lines. Also, rinse your tank through the four ports on the *underside*-- one round, two oval, one large and curved, all four in a row. Rinse them really thoroughly with warm water, then refill the tank and try the Scooba again. If it doesn't work, call us: 1-877-855-8593.
Aug 16, 2009 | iRobot 5800 Scooba Vacuum
Scooba problem
Does it put down clean water onto the floor? If so, rinse the four ports on the underside of the tank really thoroughly. You might have a clog; it's not difficult to dislodge it if you use enough warm water. Also make sure that the squeegees on the cleaning head cartridge (which holds the brush) are straight and in good condition.
If it doesn't put down water at all, try the tank rinse anyway, as it can help with that issue, too.
Jun 20, 2009 | iRobot 5800 Scooba Vacuum
I cant open my scooba
If you haven't used the scooba before or if it has been a long time, the pump may need to be primed.  Go to irobot and do a search for how to do this.  I also had difficulty opening my scooba.  Press down with the palm of your hand on the back silver plate as you push down on the silver release handle.  This worked for me.
Apr 28, 2009 | iRobot 5800 Scooba Vacuum
My scooba 5810 won't run
Fill the dirty water tank with hot water and giving the tank a good shake then pour the water out. Continue to do this until the water coming out of the dirty side of the tank is clean.
Jan 18, 2009 | iRobot 5800 Scooba Vacuum
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Scooba does not release water
I tried the straw on the solution valve. Worked last time, but no luck this time. I ended up using a can of compressed air on the solution outlets on the bottom of the unit (in the trough in front of the brush).
Jul 23, 2008 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
358 people viewed this question
Top iRobot Vacuums Experts
Dale Jones
Dale Jones
Level 1 Expert
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
