Question about Whirlpool Duet GHW9150P Front Load Washer
F11 door lock problem
The problem began when the load was heavy now any load will result in the problem and it occurs daily. Nothing seems to work in getting this repaired. Should have bought a top load at 1/2 the price. Any suggestions from anyone.
  • scott869 Sep 28, 2008
    I changed out the door lock due to breaking, now I have a f 11 error, this piece of **it is only 4 years old
  • Anonymous Oct 13, 2008
    I had the door open in the middle of a load. It was a heavy load, and it broke my door handle. I now have the door taped to do laundry until I get a new handle. Fun!
  • 750 Answers
Hello sadie172
You said, the problem began when the load was heavy now any load will result in the problem and it occurs daily. Nothing seems to work in getting this repaired.
How old is your ghw9150 washer?
Try unplugging the washer for 5minutes or turning off the breaker will do too!
then after you turn on the power the system should be reset and problem may be solved!
If for some reason the proplem persists we have available service peaople in your area listed here on our site
Let me know.
Huuum
Please remember to leave a rating!
Below is what the error code F11 is telling you.
Condition
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Things to Check
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on Oct 13, 2008
F11 & FDL error codes several times per load.
HI. this is a door lock error code.
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.((Which will be a failed door lock assembly in this case))
Aug 31, 2009 | Kenmore Washing Machines
Dl codes and f11
dL= Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
-Door Lock Mechanism broken or removed from the Door
-Check Door Lock/Switch Assembly
-Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
-Door Lock/Switch Assembly Failure
F11=Serial Communication Error
Check MCU
Check CCU
Check Motor
Check Wire Harness
Feb 07, 2009 | Kenmore Elite 45986 Front Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11 and f dl errors
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Dec 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Door locked/ cycle won't complete
If you need to get the washer door open, there is a manual release lever that you can use. The following links explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now, with your clothes rescued, the next link explains the "F11" error:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
I know it seems like a lot with the second link. In most cases I have found, the CCU is the cause of the F11 error code, but read through the information carefully and doublecheck everything. It can be replaced if you wish to perform the repair yourself. I hope this helps you.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F dL on Kenmore Elite HE3t as well as F11
Press on pause for about 15 seconds, then open the door, choose your program, close the door hard and press on start.
Mar 02, 2008 | Kenmore Elite 45986 Front Load Washer
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load - F11 Fault
I once had located a code combination to push on the control panel to clear the F11 code. I cannot locate that again. Can you please give me the combination to reset the machine?
Dec 16, 2006 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
