Question about Rane Serato Scratch Live Computer DJ Solution (Macintosh and Windows) Sound Card
Scatchlive box is faulty?
Everytime i plug my powerplug into my laptop a big static noise comes out of my speakers, but it works ok when i unplug my powerplug to my laptop. And i know the problem is definately my scratchlive box cause I swapped my serato box with my mates one and sound was sweet. Has this happened to anyone else? Please help.
  • akeem411 Nov 12, 2008
    yea! i experience the same problem and i thing the box is faulty.
3 Suggested Answers
dragon_sun25
  • 107 Answers
SOURCE: Serato scratch causes my laptop (vista) to crash
It is not fully compatible with vista. If you need more information or info on how to install xp on you laptop please contact me through www.crossloop.com/EricMitchell
Posted on Dec 10, 2008
SOURCE: Music cuts out for a split second randomely
u r facing the problem of buffer down of pcb
ju must change ur processor and ram too than u see that ur system working properly
Posted on Jul 29, 2009
Cordless phones
1) unplug all phones
2) plug them back in and check line.
If you still have the issue,!take a corded phone with. Phone jack coed to your box on the outside of the house. Usually gray, unscrew the first box - you'll see modules there - the one with the last four of your phone number is the module we'll use. Follow the directions on the box to open that module - plug your phone into the module. Here's the important thing - if you don't hear static, then the problem is from inside your house. If you call att to come out they will charge you - but that's the whole unplug the phones and centralize your base better. However, if you still hear static in the outside box, it's an att issue and have to come out at no charge.
Jun 24, 2014 | Panasonic KX-TG1033S Cordless Phone
Static coming through the speakers even though the radio is unplugged and the fuse is takin out what worng?
After I read this whole post and the solution by other guy. I came to my own conclusion is that you may have an exposed wiring that causes the static sound out of speakers. Try to look for bare wiring that may have touch each other as well as touching the metal of the vehicle. Try to disconnect the wires at the speaker, and see if it works. If it does works, then you know that you have wiring issue there.
Mar 06, 2014 | 1996 Lincoln Mark VIII
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Hi, A few days ago I asked you about my speakers, I had whistling noise coming out of the woofer. Here is your answer: sounds like a loose connection to one of the wires in the speaker. or...
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 20, 2011 | Logitech Z323 2 Speakers
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
Audio from laptop speakers is fine, headphones are not.
Do these headphones work OK in another machine??
If not they are faulty / If so then sound port may be faulty.
'Ensure it is enabled in BIOS. press DEL key when booting and look for similar.
Mar 23, 2010 | Dell Vostro 1510 Laptop
Altec Lansing BXR1121
I have same speakers, but only woffer is working, speakers doesnt work. i am really in big trouble.
Apr 24, 2009 | Audio Players & Recorders
Static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Jan 01, 2009 | Dell A215 Computer Speakers
I have purchased from Walmart 2.0 CH USB POWEREDSPEAKER SYSTEM.  UC-280.On plugging in the usb cable I get nothing from theToshbia laptop (running Vista).  The power light onthe speakers does...
Did you get a software CD with this speaker set? Check the box and ensure that it says it's compatible with Windows Vista. I'm not aware of any speaker sets that wouldn't be, but it's always a possibility.
Also, more importantly, plug in the speakers before turning the laptop on. Many powered speaker sets will not work if you plug them in while the system is on.
Apr 08, 2008 | Computers & Internet
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Computers & Internet Logo
47 people viewed this question
Top Rane Computers & Internet Experts
David Payne
David Payne
Are you a Rane Computer and Internet Expert? Answer questions, earn points and help others
