Question about Samsung CLP-500 Laser Printer
Printing computer code what what I asked for!
Frequently, when we print we get page after page of computer code instead of what we sent. We can power down the printer and start all over and it may or may not work again. Any ideas?
    Genius:
  • 1,605 Answers
Goto samsung website
http://www.samsung.com/us/function/search/resultList.do?searchWord=clp-500
download the printer driver and software.
un install the printer driver and software from control panel>>add and removed software.
install the downloaded clp-500 printer driver and software.
Posted on Nov 24, 2008
Printing cancels itself
Hey there,
The problem is probably related to the wifi connection. When the signal being sent is interupted the printer will cancel the job.
Try setting it up with a cable instead and see if that resolves your print issue. The wrinkly paper issue maybe due to you using a paper weight thinner than it would like.Try a heavier stock and ensure the paper is loaded evenly and guides are set correctly on the sides.
Oct 03, 2013 | Office Equipment & Supplies
Brother MFC prints blank pages
Try disconnecting power completely, not just turning off. Wait a few minutes and reconnect to power
Also, your print queue may be full with failed attempts at printing. The printer becomes confused and does not know what to print next. You should be able to flush the queue at the computer, but the complete disconnect and reconnect may accomplish this
Sep 04, 2012 | Brother MFC-790CW Multifunction Printer
I had cleaned my 230x printer head with iso profile after that i fitted the head into the carriage & swich on the printer i sent a printing frm computer the carriage moves left & right but...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 30, 2011 | Epson STYLUS R230 InkJet Photo Printer
Sometimes when I print .pdf file the computer request me put the file name instead of printing
this happens when you have selected a PDF printer instead of the real Physical Printer for printing
a PDF printer is a software which converts any thing sent out like a document or file for printing into a PDF file tis is useful for saving data from files or majorly from websites and emails as a softcopy on your system.
next time on, when printing check to see that the selected printer on default is a Physical Printer (like HP or Cannon etc.) connected to your computer and you'll have your hard copies
hope could be of help, cheers
Mar 28, 2011 | Computers & Internet
Print command sent from scale indicator
Change driver setting from portrait to landscape in properties/printing preferences/options page and apply setting. Verify by printing a test page. If test page prints correctly and your application still prints in portrait mode you will have to find equinalent settings page within the application
Nov 19, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Paper jam when printing onto my greeting cards
Hasn there is a roller which help the page or card to move into printer which if use frequently get so smooth that the page is not printed out instead get jam try getting printer service and replacing with New Roller.. if you don't understand any thing regarding ... ask me
Jun 23, 2009 | HP DeskJet 6540 InkJet Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Not printing the correct text / picture
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Samsung CLP-500 Laser Printer Logo
82 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
