Question about Sewing Machines
Thread gets caught in the screw behind the thread take-up lever
I have a Marie Osmond EM1 Emotions Embroidery Machine. Manufactured by Bernina and they say it is similar to the White 4400. Anyway, it is a basic embroidery machine with a computer connect.
My top thread keeps shredding around the take-up lever. I have taken this machine apart several times, taken out the bobbin and rethreaded about 100 times. On my last take, I noticed that there was thread all wrapped up around a screw that moves in a circular motion along with the thread take-up lever. The thread must be jumping past the tension disks (yes, the thread is in the tension disks and the tension is on 5.) Anyway. What would make the thread slack jump back far enough so that it can get caught on that screw/part.
  • 6 more comments
  • reneakoski Sep 25, 2008
    Took it to my gal at the sewing store and she looked at it. She reset the needle bar so it is timed better with the bobbin hook. Still shreds. She also looked at the spring hook and said it was reacting fine. I did forget to mention before that I had the machine threaded (I use a separate thread stand about 10 inches away from the machine so my thread doesn't get all twisted. . .) anyway. Either one of my cats or my kids must have knocked it down because when I came back, the thread stand was on the floor and thread was entangled across everything (probally a cat!) Maybe that knocked things out of wack since it was threaded in the machine and the presser foot was down.
    Please I hope you can offer some assistance!
    As a matter of fact. . . I did buy the wrong pre-wound bobbins and I had to rewind it onto the bobbins I was using. I have forever been using the prewound bobbins and this is the first time I used my machine to wind a bobbin. It didn't look that even when it was winding. Do you really think that is all it is????
    Yes that is my machine. The tension disks seem to be tensioning just fine. And the spring seems to be working also. thank you
    Please help!!
    Yes, the sensor goes off with a Code "13" which means thread break. It is usually shredded from the needle to the up take lever. I have been using this stand for a long time. Really basic. Just a holder (vertical) for the spool and a long guide hook up high. That is all. Thank you for your suggestions. It is great to know that you guys are out there for us.
    I will check into those, thanks.
    The screw is and was super tight!!!
  • Anonymous Mar 27, 2014
    So machine won't run. How can I take off fly wheel to clean out thread?
    Brigadier General:
  • 5,158 Answers
Examine it carefully to see if any parts were bent when the cat decided to get playful with the other device.
Robert
Posted on Sep 25, 2008
    Genius:
  • 1,011 Answers
Dear,
it might be possible that screw pulled away due to the vibration as it became loose and after working the machinary it did like this.
so try after tighting it properly.
regards,
dont rate it until it satisfies u
  • SALMAN NASEER Sep 26, 2008
    dear,
    there is a possibility of the bobbin as mensioned by u. but i think you have to check it by the technician near u or go to the speicfic shop, if possible go to its service centre.
    regards,
  • 2,071 Answers
    Sergeant:
  • 241 Answers
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
  • 5 more comments
  • Jayson Brollini
    Jayson Brollini Sep 25, 2008
    Yes if that is what your problem may be I would go back with the orginal bobbin
    My grandmother use this Model but it is a little older.
  • Jayson Brollini
    Thread break sensor alerts you to thread breaks and stops the machine  Was this sensor
    going off at all??
  • Jayson Brollini
    You mentioned that you use a separate thread stand about 10 inches from the machine.
    I know that my grandmothers had that same problem but her machine did not recommend that
    she used the bobbin table.. I think she always used it but she had problems because of it.
    Maybe you should find out if there is and adapter or some other sort of table that is the correct
    distance from the machine and the thread tension needs to correct. (Not to tight)
  • Jayson Brollini
     This is what you are suppose to use and the is tension adjustments.
    Here are the close up and you can see that this will help.
    Well I sure Hope that  my suggestions helped you.
    If they were helpful Please leave a rating for me
    Thank you
    Jayson
  • Jayson Brollini
    Well If there is anything else that I can help you with I will sure do my best.
    I can a least say that I have been around these machines and I know that
    there are a thrill to work with but they are very delicate piece of machinery.
    Here is website (link) that I think you will enjoy
    sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=27951
    Thank You  Bye
    Jayson
  • Jayson Brollini
    Well it looks like like you are still having problems...
    • It sounds like your bobbin winding mechanism could be loose.
    • Check the condition of the spool pin " see if there is any thing that may cause it not to
    keep the thread aligned.
    • Check the guide.. that goes to the threading mechanism see if that spring is not compressed.
    Jayson
  • Jayson Brollini
    make sure that your tension Ballard is not too tight!
    (if you are still not having any luck)
    I am going to give you a phone Number to a sewing machine Expert
    817-447-3522 Perfect Fit Alterations
    Ask for Neal! (over 35 years in sewing)
    He is extremely nice
    Thank You and if this advise helps
    Genius:
  • 1,847 Answers
A loosely wounded bobbin may cause this.
  • Legin Varghese
    Legin Varghese Sep 25, 2008
    a loosely threaded bobbin may cause this.
Marie osmond emotions embroidery machine
try contacting the mfg of the machine or a dealer who sell them
or try ebay
Jan 01, 2014 | Sewing Machines
if bobbin thread is bunching up, it is usually a top-needle tension issue.
Dec 11, 2013 | Sewing Machines
I didn't get the software for Marie Osmond EMotions EM1. What do I do to fix this
contact husqvarna customer service and ask them about the software
Oct 06, 2013 | Husqvarna Designer I
Artista 180 - I keep getting error message to check upper thread - happens almost every stich - changed thread, changed fabric, changed needle - error keeps happening...any ideas?
There are a number of possible reasons for this, but, assuming the thread hasn't actually broken (!), it may well be that the upper thread sensor flag has come off the check spring - this is something I see fairly regularly and is frequently the result of people pulling the upper thread 'backwards' out of the machine a bit too quickly, rather than cutting it off at the spool and drawing it through the machine in the correct direction. It's a bit fiddly and very difficult to explain how to check this, without taking all the covers off. However .... if you take the head cover off (single screw) and look carefully at the bottom of the metal takeup lever cover you will see a large slotted screw with a spring wound around it - this is the check spring. The end of the check spring pokes-out behind the takeup lever cover and the thread goes through a loop in its end when you thread the machine up. Thread the machine up as far as the takeup lever, take hold of both ends of the thread and gently raise it - you should see the check spring move upwards. Now, look very carefully at the part of the spring between the big coil around the screw and the loop where the thread passes-through ... there should be a black plastic part attached from the other side of the takeup mechanism (you cant get at this without taking the front cover off !). If it's not attached, you can very very carefully wiggle the spring and sensor flag back so that the spring sits in the slotted part of the sensor flag (either that or take it to your Bernina service agent !). If the sensor appears to be attached, it could also be the optical sensor which is attached to the front cover just above the reverse switch - sometimes this gets full of fluff or I have seen a couple with manufacturing faults where the sensor flag gets caught in the optical sensor circuit board ... whatever the case, this is really a job for the service agent.
Good Luck
Sep 12, 2011 | Bernina Artista 180
Marie Osmond emotions embroidery machine...how do i delete saved?
Check the tension. Bobbin tension. You need to use only Isacord thread. The cheap stuff will get caught and break the needle everytime.
YES you can delete designs. When the screen is up that is showing you what it is stitching. Click on grey box that pulls up everything you have ever stitched and click on one and then select delete.
Jun 17, 2009 | Yamata FY812 Mechanical Sewing Machine
Embroidery sewing machine ''emotions'' EM1
www.embroiderydesigns.com/free_embroidery_design_download.aspx
Jun 12, 2009 | Sewing Machines
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Jul 09, 2008 | Bernina Bernette Deco 600
Thread loops in top of embroidery
If it was an upper tension problem your loops would be beneith the fabric. Since the loops are on top this tells me the lower tension is too loose. There is a small screw on your bobbincase that you need to turn clockwise to adjust it. Do the adjustment little by little until its good. I would do it like a clock. First turn the screw to one o'clock. Still looping? Go to 2 o'clock etc.
If this doesn't help you, a clean opikl, and adjust by your local dealership could be anywhere from 50.00 to 90.00.
Good luck
Nov 05, 2007 | Bernina Artista 180
Embroidery
I had the same problem. It maybe you have some bits of thread caught inbetween the metal plates . That's what my problem was . Try cleaning carefully between the plates with something flat carefull not to scratch them.
Feb 25, 2007 | Bernina Artista 180
Sewing Machines Logo
764 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
